Swamp lights http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=12130 |
Author: | BayouStateHunter [ Fri Sep 03, 2010 2:50 pm ] |
Post subject: | Swamp lights |
I plan on making a swamp light bar that fits into my GT bowfishing rail mounts. My question is are y'all happy with the GT/GD/PD factory lights? They all look like tractor lights in 55 watts, right? What's y'alls experience with the spot/floods in 55 watts? I really like the LED's but they are too pricy. I saw some KC's with a black plastic housing in the $40 range (each) I just don't know if 55 watts will cut it. I plan on plugging them into my trolling motor receptacle running off my second battery. I'm just using the lights for driving and will not be on a extreme amount of time. And no, I don't want a go light or hard hat light so keep that out of the post. Thanks. |
Author: | T-Bubba [ Fri Sep 03, 2010 4:27 pm ] |
Post subject: | Re: Swamp lights |
check these out... http://www.trifectaoffroad.com/Custom-A ... oad-Light/ I heard they are pretty bright. I am thinkin about getting a set for my boat |
Author: | caddobrook [ Fri Sep 03, 2010 5:34 pm ] |
I don't like the 55 watt ones. I use ones that are 110 watts. just make sure you have heavy enough wire to handle both lights all the way to battery. 55 are not bright enough for me.. 2 110 watt with flood beams on front and a hard hat light with spot beam. All 110 watt and you are more than good to go.... just my .02 |
Author: | Orangefoot [ Fri Sep 03, 2010 5:45 pm ] |
i have two 55 watt 7 inch lights and unless you are in thick timber they are pertty much useless!! |
Author: | SP [ Fri Sep 03, 2010 6:19 pm ] |
The stock PD lights are useless. I barely use them. I just use my Q beam. If anybody knows of a good pair of lights that will fit in the PD bracket I am all ears. |
Author: | JIMMY W [ Fri Sep 03, 2010 6:58 pm ] |
Author: | cb5331 [ Fri Sep 03, 2010 7:29 pm ] |
