It is currently Sat Nov 29, 2025 9:24 am
Reply to topic  [ 4 posts ]
 Advancing timing on outboard
Post Advancing timing on outboard
Does anyone on here know how to advance the timing on a 40 Merc?
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Wed Oct 13, 2010 3:30 pm
Post Re: Advancing timing on outboard
www.evolutionmarine.net
Wed Oct 13, 2010 3:32 pm
Theres two different timing adjustments, one for idle and one for WOT. The trigger coil is mounted under the flywheel with the stator. The trigger coil is attatched to the throttle linkage. There is two different stop screws for idle or WOT timing adjustment.
Thu Oct 14, 2010 9:37 pm
DMC is right but don't go over what the manufacturer recommends, you could cause some serious engine damage to it so make sure you use a timing gun when you do this with the engine in the water. I used to mark the flywheels with liquid paper to see the timing marks more clearly.
"We Are Products Of Our Decisions"
Tue Oct 19, 2010 8:49 pm
