| Avery pop up or quick set blind http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=13991 |
| Author: | swamphonkey [ Tue Nov 23, 2010 8:51 pm ] |
| Post subject: | Avery pop up or quick set blind |
Does any-one own of these pos! I got one off a friend, and its real wobbley when its up. Do I need to put some lateral straps on this thing or something cuz I'm tired of jacking with it. |
| Author: | Team Camo [ Tue Nov 23, 2010 9:55 pm ] |
| Post subject: | Re: Avery pop up or quick set blind |
Should have some straps or ropes holdin it up & keepin it stable. Also, should have some clips holdin the bottom to the gunnel. If not, get some & try that. |
| Author: | 50fps [ Thu Nov 25, 2010 1:36 pm ] |
Move the bases closer to each other a bit. It should take a little effort to lock the uprights into position when properly spaced. |
| Author: | THE_RAGE_N_CAJUN [ Sat Dec 04, 2010 5:36 pm ] |
i got a mudbuddy shaggy blind and it is held up by like backpack straps from edges of boat to the top rail and to the middle of the up position never had any problem and shouldn't take much to ad to your blind lowes and walmart prob has everything you need |
| Author: | Phathead [ Sat Dec 04, 2010 9:39 pm ] |
if its wobbly you probably didn't put it together correctly or attach it to the boat correctly. Take some pictures of the blind on the boat in the up position with the material out of the way and we should be able to help you. |
| Author: | swamphonkey [ Sun Dec 05, 2010 9:03 am ] |
I got all the bugs worked out of this thing. I still think it takes a long time to wrap it up! I used rubber hose on the long support washers instead of the tape that avery recogmends. its been on 2 other boats but for 250 I really can't complain much the material would have cost that so thanks guys! |
