It is currently Thu Dec 18, 2025 8:34 pm
[ 6 posts ] |
Avery pop up or quick set blind
swamphonkey
Joined: Mon Nov 15, 2010 6:36 pm Posts: 122 Location: Longview,Tx
Does any-one own of these pos! I got one off a friend, and its real wobbley when its up. Do I need to put some lateral straps on this thing or something cuz I'm tired of jacking with it.
_________________ GDSD 1660 runnin a 35gdsd
| Tue Nov 23, 2010 8:51 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Avery pop up or quick set blind
Should have some straps or ropes holdin it up & keepin it stable. Also, should have some clips holdin the bottom to the gunnel. If not, get some & try that.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
| Tue Nov 23, 2010 9:55 pm |
50fps
Move the bases closer to each other a bit. It should take a little effort to lock the uprights into position when properly spaced.
| Thu Nov 25, 2010 1:36 pm |
THE_RAGE_N_CAJUN
Joined: Sun Jul 04, 2010 8:17 pm Posts: 40 Location: thibodaux ,la
i got a mudbuddy shaggy blind and it is held up by like backpack straps from edges of boat to the top rail and to the middle of the up position never had any problem and shouldn't take much to ad to your blind lowes and walmart prob has everything you need
| Sat Dec 04, 2010 5:36 pm |
Phathead
Joined: Thu Jan 15, 2009 8:23 pm Posts: 225 Location: Arkansas
if its wobbly you probably didn't put it together correctly or attach it to the boat correctly. Take some pictures of the blind on the boat in the up position with the material out of the way and we should be able to help you.
| Sat Dec 04, 2010 9:39 pm |
swamphonkey
I got all the bugs worked out of this thing. I still think it takes a long time to wrap it up! I used rubber hose on the long support washers instead of the tape that avery recogmends. its been on 2 other boats but for 250 I really can't complain much the material would have cost that so thanks guys!
| Sun Dec 05, 2010 9:03 am |
[ 6 posts ] |
