It is currently Sun Jul 20, 2025 11:31 pm
Reply to topic  [ 9 posts ]
 Transom Angle on Pro-Drive boats?
Post Transom Angle on Pro-Drive boats?
After reading several posts about how important transom angle is to Pro-Drive motor performance, and searching without success to figure out what that angle was, I thought mebbe someone here could tell me.
Looks like my transom is about 11 degrees, am I missing some performance?
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Sat Feb 05, 2011 11:11 am
Post Re: Transom Angle on Pro-Drive boats?
I believe it is 10-12 degrees. I would think you would be fine. Hull performance also will be related to weight distribution.
Crisis defines character
Sat Feb 05, 2011 11:31 am
Sat Feb 05, 2011 12:07 pm
16 degree
and on a long shank, go with a 19" transom
Sat Feb 05, 2011 7:37 pm
Regardless what anyone tells ya, it dont fkn matter. Play wit da trim til ya get it where it runs best.I have a GTR that is on a boat that had a 40 mercury, then a Pro Drive and now a GTR. It ran like a raped ape wit all of em.
Sat Feb 05, 2011 7:48 pm
Sun Feb 06, 2011 12:20 am
The more angle, the deeper you can get with prop.. With a GT, it may not matter as much, but I truely believe that with a PD it does. SHIM it correctly, and you will see a difference in performance when in solid mud. That is the only time it will help.
Sun Feb 06, 2011 6:52 am
I've always heard it was 15 degrees but call them and ask
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Mon Feb 07, 2011 5:11 pm
Update - Tracker transom angle is 17 deg, measured height is 20 3/8" at the keel. That makes apparent transom height = 19 1/2".
Sounds like that's just about where it's supposed to be.
Tue Feb 08, 2011 2:13 am
Users browsing this forum: No registered users and 62 guests
