It is currently Thu Jul 24, 2025 5:04 am
Reply to topic  [ 10 posts ]
 standard GT hull vs. extream GT hull
Post standard GT hull vs. extream GT hull
Looking to get my first mud boat and i am stuck between standard GT hull and the xtream Gt hull. What are some of the pro's and con's of the two? I will be running either a 17x54 or an 18x54 with a 36gtr. I will be running in some thick grass and souppy mud and alot of log crossing. Let me know what cha think.
Tue Mar 15, 2011 4:06 pm
Post Re: standard GT hull vs. extream GT hull
Where u live, best thing is to ride in each one and make your decision.
Gator tail
Tue Mar 15, 2011 5:55 pm
The extreme turns without sliding. The regular slides in a turn,with a narrower hull it's not bad but 54 an 60's will slide.
Tue Mar 15, 2011 6:12 pm
i live in centrul Louisiana and i don't really have any one to give me a test run but was just wanting to know the pro's and con's of each
Tue Mar 15, 2011 6:14 pm
All pro's....only con is it cost 700-800 dollars more.
Tue Mar 15, 2011 6:34 pm
Tue Mar 15, 2011 7:30 pm
What they said
Wed Mar 16, 2011 12:33 pm
Thanks for the info guy's it almost sounds to good to be true LOL. Not a one bad comment at all that doesn't happen to often figured there would have been more comments on this subject but it's all good so far thanks again guy's.
Wed Mar 16, 2011 4:10 pm
I'll say this if they had the extreme when I bought mine I'd have the xtreme.
Wed Mar 16, 2011 5:39 pm
I came up with the idea of a pad on a mudboat. Besides turning well it will push pole and track with a trolling motor better than a slick hull. I pole the flats for redfish in mine.
In some bottoms types it will do a little better than a flat bottom , In most its about even. Its a faster hull if they are the same weight, but in al. it's hard to make them weigh the same. Add frog spit to the bottom it makes a big differance. Its a little harder to built.
With a 40 hp out board it will hall ass.
JD
Wed Mar 16, 2011 8:38 pm
Users browsing this forum: No registered users and 89 guests
