It is currently Tue Jul 22, 2025 5:44 am
Reply to topic  [ 27 posts ]
 Painting a boat floor?
Post Painting a boat floor?
Im going to be picking up my new hull from Jason next week sometime and I will be painting it myself. I am throwing around some ideas on how to paint the floor and other flat surfaces of it to keep it from being slick when wet. Any ideas? I dont want to hydroturf it. Also how well does putting a store bought bedliner material work? anyone ever done it? How aout sherwin williams sharkgrip? Its supposed to add grip but i have never used it?
1848 Prodigy
35 GTR
Thu Mar 10, 2011 12:26 pm
Post Re: Painting a boat floor?
If you're just lookin for non slip, go to Lowe's paint dept & pick up a bag of sand to add to ya paint. It's a small blue bag about the size of a qt ziploc baggie. I can't remember the name of it, but it was near the garage floor paint. The directions said to mix it into your paint & apply it with the brush or roller, do NOT do that. All it will do is clump up. Apply a coat of paint & spread some sand over it, then apply a 2nd coat of paint over the sand to seal it in. Works as good as the paint you're using.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Mar 10, 2011 12:44 pm
I picked up some Rustoleum bed liner in the gallon from the Walmart for 45 bucks, mixed half a coffee cup of bead blasting material, and coated my floors about 3 times between drying. I am very happy with it! It is a rough surface so no slipping. I would put it up against any Rhino Liner or Line-X out there!
"Drop the Hammer"
Excel 1651 F4 with a Mud Buddy HD7000
Excel 1860 F4 with a Mud Buddy HD5500
Thu Mar 10, 2011 12:55 pm
if you can get your hands on some crushed walnut shells to either mix in your paint or paint one coat then sprinkle out over your floor, let dry and put another coat over them. the crushed shells work excellent.
Thu Mar 10, 2011 1:36 pm
Bed liner + mud = slick as Owl $hit
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Thu Mar 10, 2011 2:15 pm
Thu Mar 10, 2011 2:21 pm
My buddy owned a rhino liner dealership until a couple of years ago, he highly recommend against putt'n it in my boat.
Thu Mar 10, 2011 3:06 pm
x2 on the sand and good paint. Forget Lowes, they want too much for for something you can get free. I found a nearby construction site where they mix concrete on the spot and got a pint or so of their fine sand. Playground sand works good, too. I had no trouble with it clumping, as i didn't use too much and stirred it in real well with the paint in a paint tray. It'll last longer if you apply thin and let each coat tack up a bit. Apply two or three coats and you're good to go.
Thu Mar 10, 2011 6:02 pm
turtle / fish tank sand is what i used sprayed the first coat of paint then sprinkled sand on to the texture i wanted then sprayed the second coat came out great
Thu Mar 10, 2011 7:06 pm
DO NOT USE BEDLINER!!! I'm thinking of scrappin that crap off my boat. If you need crushed walnut shells go to a pet store and it is in the reptile department for bedding. if you want the best get hydroturf and be done with it
"I have been blessed with many things in this life, an arm like a rocket, a c*ck like a Burmese Python and a mind of a f*ckin scientist."
-Kenny F*ckin Powers
Gator Trax 3-Man Gatorhide with a Mud Buddy HD Sport 5000
Large Big Green Egg with rounded chines
Thu Mar 10, 2011 7:23 pm
I feel like the sand will just wear off really quickly.. Is this the case? I dont want to afro engineer anything but i also dont want to throw another $800 or so at hydroturf. Im sure it is good but i will have to wait a little while and save some money to do that.
I have had bad experiences with bed liner in boats...it just never seems to work out very well. Does the sand in the paint actually last or is it a ghetto fix?
1848 Prodigy
35 GTR
Thu Mar 10, 2011 9:01 pm
Do it yourself. You can hydroturf the boat for under 200 bucks... They have factory second's on their web page cheap.
Thu Mar 10, 2011 9:05 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Mar 10, 2011 9:08 pm
Thu Mar 10, 2011 9:44 pm
If done right the sand will work
We have it on rigs and it has been there for years
Aucoin 20X48 36pd
Thu Mar 10, 2011 9:51 pm
1848 Prodigy
35 GTR
Fri Mar 11, 2011 12:03 am
I used parkers duck boat in dead grass and I like it. The color was a bit iffy at first but it grew on me. I also used an automotive primer that a guy recommended to me that really helped it hold, so far it has hardened really well and I haven't seen any flake/chip/or scratch off yet. i also have about half a gallon left over after painting my boat so if it were to get scratched or chipped ill have a bit more to touch it up, if need be. Check out my build to see how my boat turned out.
1436 Lowe
Fri Mar 11, 2011 12:44 am
Bro if your gonna do this use the sand like said before BUT don't use reggular paint the sand will pell off the paint . Use two part epoxy with a flatting agent , it will not come off.
1746 with a modded 35 gdsd
Capt Team total asalt
Thu Mar 17, 2011 5:04 pm
http://www.cabelas.com/product/Cabelas- ... l+Products
I did this to my last boat. I used a gallon and did the entire floor, front deck, gun box and top of gunnels with 2 coats. Very easy to put on with a rollr and extremely tough!! Lasted thru 5 duck seasons and i only had to redo one spot because the saw leaked gas...scraped around the edge and re-rolled that spot and it was as good as new!
This was what it looked like after 5 years of steady use! Olive green
1854 Brotha Breaux chased by 36 PD!
Thu Mar 17, 2011 5:38 pm
1848 Prodigy
35 GTR
Fri Mar 18, 2011 12:09 am
Use Duralux M736 it will stick to bare aluminum after you wash it with aluma brite to etch the surface. spray on a light coat sprinkle sugar sand aka blasting sand then put on a good heavy caot of pait to finish it. dont use play sand or the sand for traction from Lowes or Home Depot it is too big and will "roll" causing you paint to come off where ever the grains are. Duralux can be bought from Ace Hardware in Covington 985-893-1212 <----- number for Ace... O'reily's has the aluma brite.
Fri Mar 18, 2011 5:21 am
Fri Mar 18, 2011 5:43 am
A gallon did the entire boat and had a little left over! Yes it will take a hold paint really well! It was an easy way to have a non skid tough surface for about 80 bucks! I will look and see if i got any more pics with paint on the tuff coat.
Fri Mar 18, 2011 8:10 am
Can't think of a single reason you wouldn't want hydroturf? It's only a couple hundred bucks if you get the diamond pattern grey stuff, and nothing else comes close to being as nice.
24x60 Dual Prodrives
Fri Mar 18, 2011 4:22 pm
1848 Prodigy
35 GTR
Fri Mar 18, 2011 6:39 pm
Fri Mar 18, 2011 7:02 pm
Sat Mar 19, 2011 7:55 pm
Users browsing this forum: Google [Bot] and 66 guests
