It is currently Sun Jul 13, 2025 2:16 am
Reply to topic  [ 18 posts ]
 POP UP BRAND BLINDS
Post POP UP BRAND BLINDS
Should take delivery of my new rig in a coupe of weeks. 18X54 gator tail with a 35 gtr. Will be huntin the rivers and lakes around central Louisiana mostly. Anyone had any experience with the popup brand blind. Would like something water proof for the Ducky Days.
Sat Feb 28, 2009 2:49 pm
Post Re: POP UP BRAND BLINDS
Had one and did not like it at all, didn't hide well, couldn't grass it and it stuck out like a sore thumb. payed over 1000.00 on it just to cut it up and make a crappy fast grass look a like that was a hundred times more effective.
CVN73 Plank owner
Bad spellers of the world untie!!!!!
Sat Feb 28, 2009 3:29 pm
I have a cabelas flip top boat blind and If you hunt by yourself alot I wouldnt suggest getting that one. Its a real pain in the ass to set-up. it does hide nice but I only give it a 3 out of 5 because of how much it weighs and the roof (while it does do a nice job of keeping yo dry) is so freaking heavy when you go to lift it up to shoot I had to add assisted lift bungees over the top of it to make it doable.
Mon Mar 02, 2009 5:48 pm
Mon Mar 02, 2009 5:49 pm
Thanks for the reply. Good lookin blind but it does look heavy, did you have to put that much grass on it to make it blend. Startin to consider the shaggy pro by mudbuddy now, not water and wind proof but a bunch lighter. anyone use one this year
Mon Mar 02, 2009 7:14 pm
I saw go-devil is making them now. They look pretty good. They appear to be real easy to operate. Look on their website, it maybe worth checking out.
Mon Mar 02, 2009 10:05 pm
We use and sell alot of the Duck Island blinds. They are the lightest of all of them and have really good overhead cover, are very, very easy to put up and down and are fully adjustable. Only down side is they are light, in that the tubing is thin and it can get bent and or broken over time. So far they have been really good at replacing the few we have had needing replacment parts. I guess it is all a compromise, save weight vs. over built. I have personnally used mine for three full season and have not had any issues with it.
PW
Paul V. Willging - Owner
Phowler Boat Company
Illowa Marine
1701 Main Avenue, Clinton, Iowa 52732
563-242-8969 or cell 563-212-7091
email: larrys-prodrive@mchsi.com
http://www.larrysillowamarine.com
Tue Mar 03, 2009 8:36 am
The MB shaggy blind as you stated is not waterproof or windproof and it is lighter UNTIL you get that sucker soaking wet and then it is heavy as a biotch!
An Avery quickset with the rain tops and 2 killerweed boat blind kits is the ticket for me. Windproof, waterproof to a degree that is acceptable, and good 3d effect to break up boxiness. Plus there is plenty of room inside the blind. I wouldn't worry about waterproof qualities you're duck hunting so you are probably wearing goretex or equivalent anyway.
Tue Mar 03, 2009 10:43 pm
i have the go devil pop up & really like it. the only other i've hunted is the gator tail & the main difference is that the gd telescopes out after you raise it for better concealment (& in when down to get it inside the gunnels). it provides pretty good wind protection & modest (sideways) rain - but it's (of course) for camo & i think it does a great job where i hunt. i've heard gd has avery make it. it's pretty heavy duty, but you do have to make sure the drunken fools on your boat don't get retarded on it - mainly using it to stand up.
Gator Tail GTR35 on a Go Devil 16x56
Wed Mar 04, 2009 9:14 am
Get the Go Devil brand and be done with it.
Wed Mar 04, 2009 1:42 pm
Just looked at the go devil blinds and the frame does look like it would be heavier which is good. The grass looks almost white but i guess you could put some paint and a little brush and moss on it.
Yes I will have my gortex on but the rain sure splatters bacon and sausage grease alot not to mention makin your biscuits soggy. Thats how I pass the time between squeller time and mallard time. Plus mabe a little nap.
______________________________
18X54 GT 35GTR
All it takes for evil to prevail is for good men to do nothing!
Wed Mar 04, 2009 3:13 pm
Just make a scissor blind out of 3/4 in EMT conduit piping and bimini hardware for cheap. Get fast grass and netting. I have the Cabelas Northern flight to and built my own fliptop. I'm going to modify the lower end blind soon because it sticks out past the gunnels and the grass only last 2 years max.
Josh
"Grace calls us to change and then gives us the power to pull it off!"
Max Lucado
Fri Mar 06, 2009 9:59 am
Theres alot of nice blinds out there .
If you choose to build your own here is a good link.
http://www.kwicklabs.com/images/Scissor ... Photos.htm
THE, FIRST and ONLY MMT Member of the Year!
Sat Mar 07, 2009 9:28 pm
This mine that I made.
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Tue Mar 31, 2009 6:24 am
I made my own frame and put MB Shaggy Panels on it- blends in everywhere, makes stuff disappear. They are all heavy if they get wet. Works well for me:
Thu Apr 02, 2009 8:13 pm
also check out beavertail blinds they are alot like go devils blinds and easy to set up and everything flips to one side when down for driving
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Mon Apr 06, 2009 8:51 am
Shallow Water Marine, in Palo Iowa makes the best soft sided blind on the market. When the blind is up, it is low profile and you can stand on top of it!!!!!!!!! It will take all the brush you can put on it, and still fold down. Check em out at www.sw-marine.com
Wed Apr 22, 2009 6:45 pm
i dont have any pictures but i use an avery quick set blind and i really like it. its quick puttin up, hides good, and has a net over the die cut material that you can put vegetatio in to help blend even more. it also wasnt too expensive.
Tue Apr 28, 2009 9:31 pm
Users browsing this forum: No registered users and 84 guests
