Prodrive and pirouge make over...... http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=17261 |
Author: | Mudhole [ Mon Mar 28, 2011 7:09 am ] |
Post subject: | Prodrive and pirouge make over...... |
Warning, picture heavy! lol Ok, waited a while before deciding to post this, but figured I'm close enough to being done with it, so here goes...... Ordered some trays and had the welded in...... Then took every out of the boat, pulled the motor and slide it off the trailer, then flipped it over and started sanding! Ground the botton with a 40 grit flap wheel for steel flex. Decided to do the roe as well as it needed some TLC after several years of abuse! During the sanding found this lil oops, it was on the bottom of the bow hook so never saw it before hand...... Took it to Andy and got her fixed up...... Taped off the areas for the steel flex...... Then mixed a full gallon and poured it on both hulls, and spread with foam rollers...... Once the steel flex had cured, shot AG primer over all the bare aluminum...... Then srayed the base coat on both hulls and the gun box...... Then start with the stenciles...... After I was finished with the outside and it had cured good, got some friends over to help me flip it back over, got it set up, I started on the inside with sanding and more primer...... Then back to the steciles, it's a beach trying to do this by yourself with a 20 mph wind blowing..... After the inside paint had cured, ran all my wires back, and hooked up all the switchs and such, the cranked it back on the trailer and hung the motor back on...... Ordered hydro turf for the floor and got that put down, again, no easy task by yourself...... Still have to get my numbers painted on as well as new stickers, weather has turned off cold again, so no painting! And I'll hydro turf the front deck at a later time, my boats been down for like two months now, and I'm ready to get it back on the water!!!! |
Author: | T-Jacques [ Mon Mar 28, 2011 7:28 am ] |
Post subject: | Re: Prodrive and pirouge make over...... |
just how many sheds do you have??? |
Author: | Mudhole [ Mon Mar 28, 2011 7:32 am ] |
Just de shop, those others are my neighboors, and yea I need a fence!! |
Author: | diceman [ Mon Mar 28, 2011 7:34 am ] |
Author: | jordy [ Mon Mar 28, 2011 8:36 am ] |
fine job my friend. |
Author: | BROOKS [ Mon Mar 28, 2011 9:29 am ] |
Well there you go .... just like that .... a Brand New BoatHull !!!! ![]() Great job .... you should be proud !! Querston ~ Whys SteelFlex ?? .... yore hull didn't look that bad .... also .... how much dolla's in material you thank you gots ? |
Author: | bpurvis [ Mon Mar 28, 2011 9:39 am ] |
awesome job! what brand of paint did you use?? |
Author: | Sko [ Mon Mar 28, 2011 12:58 pm ] |
Nice work |
Author: | oncall [ Mon Mar 28, 2011 3:16 pm ] |
Very nice! Looks like a new rig. |
Author: | Mudhole [ Mon Mar 28, 2011 8:09 pm ] |
Brooks......steel flex was like 125 a gallon with the color tint, paint from Lock Stock and Barrel was 180, stenciles 100 and a couple months of work! |
Author: | atlong [ Mon Mar 28, 2011 8:14 pm ] |
what pattern of hydro turf is that? u did a great job on that it looks great |
Author: | Mudhole [ Mon Mar 28, 2011 8:17 pm ] |
The nat gear from GT |
Author: | whytry85 [ Mon Mar 28, 2011 8:23 pm ] |
looks awesome! great job!!! |
Author: | Team Camo [ Mon Mar 28, 2011 8:31 pm ] |
Damn fine job, right there. Wish my paint was as nice. |
Author: | MeatWagon [ Mon Mar 28, 2011 10:25 pm ] |
Nice Job |
Author: | chocolate head [ Tue Mar 29, 2011 7:22 am ] |
Nice job, looks great! Hey Brooks just name the whole thing, think it would be too tough to name each one. ![]() |
Author: | HIGGS [ Tue Mar 29, 2011 8:48 am ] |
awesome project man! |
Author: | mcnemar1982 [ Tue Mar 29, 2011 9:19 am ] |
Got that thing looking good myboy! ![]() |
Author: | Woodiebuster [ Tue Mar 29, 2011 4:12 pm ] |
You ought to change over to tall transom while its apart. |
Author: | duramaxdiesel09 [ Tue Mar 29, 2011 10:29 pm ] |
Very Nice!! |
Author: | earl33 [ Wed Mar 30, 2011 6:47 am ] |
Some folks dont know how much time and work it takes to paint one up, but I beat you know..... Nice job, looks dam good.... |
Author: | Mudhole [ Wed Mar 30, 2011 8:23 am ] |
Earl....ya got that right, especially when ya working outside in ya yard! Now if ya had a place that ya could put the boat in, now ya could prob do one in a week! |
