Boat Prep for paint http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=18264 |
Author: | T-Bubba [ Tue May 03, 2011 8:02 pm ] |
Post subject: | Boat Prep for paint |
I am about to repaint my boat and I am wondering if anyone has sandblasted theirs. What sand do you use? I read to use aluminum oxide sand blasting sand becuase silicon carbide will contaminate the aluminum. I have a lot of pealing paint and need to get it off. Sandblasting it would be easier than sanding the entire boat. |
Author: | SmokeEater829 [ Tue May 03, 2011 8:06 pm ] |
Post subject: | Re: Sand Blasting |
I think I remember reading to NOT sandblast! Do a search and see what comes up. |
Author: | Robn1020 [ Tue May 03, 2011 8:07 pm ] |
Author: | Sko [ Tue May 03, 2011 8:10 pm ] |
Post subject: | Sand Blasting |
To much pressure sandblasting. Might warp the aluminum in some spots |
Author: | T-Bubba [ Tue May 03, 2011 8:12 pm ] |
I guess a wire whell on my 7" dewalt will do the trick. I dont want to sand blast it but my dad thinks it can be done and will be helping me with it. |
Author: | dog walker [ Tue May 03, 2011 8:13 pm ] |
I forgot who it was but they had pics of hull that was sand blasted and that mofo was trashed!!!! |
Author: | fishon!! [ Tue May 03, 2011 8:17 pm ] |
how expensive is aircarft grade paint stripper? |
Author: | SmokeEater829 [ Tue May 03, 2011 8:19 pm ] |
Thats the post i was talking about. That boat was garbage after blasting. |
Author: | SmokeEater829 [ Tue May 03, 2011 8:21 pm ] |
Check this thread out! Might help you make your mind up. |
Author: | kibb [ Tue May 03, 2011 8:23 pm ] |
I dont believe it's the pressure, it's the heat generated using silica. See if you can find someone that can do it with walnut shells. |
Author: | T-Bubba [ Tue May 03, 2011 8:24 pm ] |
my dad has all the equipment... i'd just have to find the walnut shells |
Author: | Robn1020 [ Tue May 03, 2011 8:27 pm ] |
Forgot to add I used KS 3 Stripper you buy at home depot before the orbital. I had 7 layers of paint on mine. Lots of coats of that walmart camo over factory paint. Brushed that $hit on and hit it with a power sprayer. Almost took all the paint off by itself. The orbital sander and wire wheel just helped make the sumbitch shine. |
Author: | T-Bubba [ Tue May 03, 2011 8:52 pm ] |
after you used to stripper did you pressure wash it. I bet I could get most of the paint off with a pressure washer then apply the stipper then wait 15-20 min and pressure wash it off |
Author: | kibb [ Tue May 03, 2011 8:54 pm ] |
That sounds like the ticket. |
Author: | Robn1020 [ Tue May 03, 2011 8:58 pm ] |
Author: | T-Bubba [ Tue May 03, 2011 9:24 pm ] |
aight thanks for the tips.. I think my pressure washer is 3400psi so that with the stripper should work well |
Author: | Robn1020 [ Tue May 03, 2011 9:45 pm ] |
Author: | lftdjeep426 [ Thu May 05, 2011 9:30 am ] |
Post subject: | Re: Boat Prep for paint |
I just got through doing mine..... Used Oven Easy Off from the dollar store. Took two coats and a 3600 psi power washer. Took of three layers of paint. I set the boat in the sun, sprayed on, let set for 15 minutes and power washed off. Before: After: Will still have to do a little sanding but it took 90% of everything off in about 2 hours with minimal work. Getting ready to SteelFlex the Bottom/Sides..... Just my $0.02 |
Author: | greg f [ Thu May 05, 2011 10:47 am ] |
If you use that paint stripper be sure to prime the aluminum before you paint it or you'll be back to where you started. |
Author: | lftdjeep426 [ Thu May 05, 2011 11:03 am ] |
A "Self Etching" primer..... |
Author: | T-Jacques [ Thu May 05, 2011 11:06 am ] |
You can blast it, just have to use a very light sand flow. You can also blast it using baking soda. Not sure where you would find that. Dude I know blasted an old fiberglass Whaler with it. |
Author: | kibb [ Thu May 05, 2011 3:08 pm ] |
Aisle 8, next to the flour. ![]() |
Author: | Rambeaux [ Thu May 05, 2011 3:48 pm ] |
I was going to help your ass with that. Until i saw that post. |
Author: | T-Bubba [ Thu May 05, 2011 3:50 pm ] |
lmao... dont be mad.. |
