It is currently Mon Dec 15, 2025 10:51 pm
Reply to topic  [ 24 posts ]
 Boat Prep for paint
Post Boat Prep for paint
I am about to repaint my boat and I am wondering if anyone has sandblasted theirs. What sand do you use? I read to use aluminum oxide sand blasting sand becuase silicon carbide will contaminate the aluminum.
I have a lot of pealing paint and need to get it off. Sandblasting it would be easier than sanding the entire boat.
I gave up mud motors
Tue May 03, 2011 8:02 pm
Post Re: Sand Blasting
I think I remember reading to NOT sandblast! Do a search and see what comes up.
Mud Buddy 4500 Black Death hauling the Uncle J 18x58
Tue May 03, 2011 8:06 pm
Tue May 03, 2011 8:07 pm
Post Sand Blasting
To much pressure sandblasting. Might warp the aluminum in some spots
18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Tue May 03, 2011 8:10 pm
I guess a wire whell on my 7" dewalt will do the trick.
I dont want to sand blast it but my dad thinks it can be done and will be helping me with it.
Tue May 03, 2011 8:12 pm
I forgot who it was but they had pics of hull that was sand blasted and that mofo was trashed!!!!
Tue May 03, 2011 8:13 pm
how expensive is aircarft grade paint stripper?
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Tue May 03, 2011 8:17 pm
Thats the post i was talking about. That boat was garbage after blasting.
Tue May 03, 2011 8:19 pm
Check this thread out! Might help you make your mind up.
Tue May 03, 2011 8:21 pm
I dont believe it's the pressure, it's the heat generated using silica. See if you can find someone that can do it with walnut shells.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue May 03, 2011 8:23 pm
my dad has all the equipment... i'd just have to find the walnut shells
Tue May 03, 2011 8:24 pm
Forgot to add I used KS 3 Stripper you buy at home depot before the orbital. I had 7 layers of paint on mine. Lots of coats of that walmart camo over factory paint. Brushed that $hit on and hit it with a power sprayer. Almost took all the paint off by itself. The orbital sander and wire wheel just helped make the sumbitch shine.
Tue May 03, 2011 8:27 pm
after you used to stripper did you pressure wash it.
I bet I could get most of the paint off with a pressure washer then apply the stipper then wait 15-20 min and pressure wash it off
Tue May 03, 2011 8:52 pm
That sounds like the ticket.
Tue May 03, 2011 8:54 pm
Tue May 03, 2011 8:58 pm
aight thanks for the tips..
I think my pressure washer is 3400psi so that with the stripper should work well
Tue May 03, 2011 9:24 pm
Tue May 03, 2011 9:45 pm
Post Re: Boat Prep for paint
I just got through doing mine..... Used Oven Easy Off from the dollar store. Took two coats and a 3600 psi power washer. Took of three layers of paint. I set the boat in the sun, sprayed on, let set for 15 minutes and power washed off.
Before:
After:
Will still have to do a little sanding but it took 90% of everything off in about 2 hours with minimal work. Getting ready to SteelFlex the Bottom/Sides..... Just my $0.02
1648 Lundau W/ MudBuddy 23hp LT(Work in Progress)
Thu May 05, 2011 9:30 am
If you use that paint stripper be sure to prime the aluminum before you paint it or you'll be back to where you started.
Thu May 05, 2011 10:47 am
A "Self Etching" primer.....
Thu May 05, 2011 11:03 am
You can blast it, just have to use a very light sand flow. You can also blast it using baking soda. Not sure where you would find that. Dude I know blasted an old fiberglass Whaler with it.
Thu May 05, 2011 11:06 am
Aisle 8, next to the flour. ;)
Thu May 05, 2011 3:08 pm
I was going to help your ass with that. Until i saw that post.
36 PD FPR on a PD X-Series 18X54
Thu May 05, 2011 3:48 pm
lmao... dont be mad..
Thu May 05, 2011 3:50 pm
