It is currently Thu Jul 24, 2025 9:58 pm
Reply to topic  [ 10 posts ]
 GTR pulls a little
Post GTR pulls a little
alright gator tail people mine pulles a little and throws a rooster tail 20ft to the side if i tweek that torque tab a little that otta fix it ????
1848 Cajun Performance GTR35
IF YOU AIN'T RUNNING WITH ME,,,,THEN RUN FROM ME!!!!!!!!!!!!
Mon May 23, 2011 5:45 pm
MMT Moderator
Post Re: GTR pulls a little
balance your load first these boat/motor setups are very sensitive to weigh distribution. You can add a torque tab or slightly bend your skeg. Torque tab works for me
GTB 1860 w/ 2019 GTR40XD-HO
Mon May 23, 2011 5:51 pm
Load placement in the hull can have alot to do with tiller torque. Was the boat empty or did you have stuff or people in it? Sometimes mounting the motor slightly off center,usually an inch can help. Sounds like you may have the motor trimmed too high if you are throwing a rooster tail that big.
Mon May 23, 2011 6:12 pm
Mon May 23, 2011 6:14 pm
Mon May 23, 2011 6:20 pm
tab
Mon May 23, 2011 6:32 pm
i think if i put a cresent wrench on it ill be okk ????
Mon May 23, 2011 6:48 pm
It's pulling away from you? If so then try bending back towards the skeg a lil bit and try it out. A large crescent should work.
Mon May 23, 2011 6:56 pm
Mon May 23, 2011 7:01 pm
Users browsing this forum: No registered users and 143 guests
