MM and Jack Plates - Question
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=18640
Author:  Hambone [ Thu May 19, 2011 10:00 am ]
Post subject:  MM and Jack Plates - Question
Got a question on using a jack plate with a MM. Here is my set-up. I have a custom built john boat for duck hunting small water. Got tired of flimsy, thin and tipsy small johns so I had one made to my specs. It is 11 ft long but 48 wide across the bottom. Hull is .100 g and the sides are deep. Transom is 19". Looking at a Copperhead 10hp but transom is too tall. I can add a fixed jack plate that will get the Copperhead down to the right trim and it has a 4" setback. Looks to me like it should work. Anybody have experience with jack plates and MM? The plate I am looking at is rated for up to 35HP.
Author:  garrettpearce [ Thu May 19, 2011 11:02 am ]
Post subject:  Re: MM and Jack Plates - Question
you probably wont be able to tilt the motor due to it hitting the stern
Author:  po po mud duck [ Thu May 19, 2011 11:15 am ]
I bought this used 2004 Hyper Drive. The previous owner traded the original 48" drive for the 27" drive you see in the picture. When I purchased this motor I knew absolutely nothing about them and to top it off it was a complete basket case. I've restored the engine and frame and had to build a jack plate to make the engine work on my boat. I have 10 hours on it now and I'm pleased with the motor. It handles and performs well.
Author:  BradS [ Thu May 19, 2011 11:32 am ]
Author:  Brinkleydog [ Thu May 19, 2011 12:16 pm ]
:idea:
Author:  MaXXis85 [ Thu May 19, 2011 12:19 pm ]
Turbocharged Vanny..... I hope you dont have decked heads.
Author:  WestEndAngler [ Thu May 19, 2011 1:03 pm ]
:lol: well I guess I could go bolt a supercharger on the top & make mine look cool :lol:
Author:  po po mud duck [ Thu May 19, 2011 1:12 pm ]
Author:  po po mud duck [ Thu May 19, 2011 1:30 pm ]
Author:  MaXXis85 [ Thu May 19, 2011 1:34 pm ]
3 blade cleaver I assume?
Author:  Hambone [ Thu May 19, 2011 7:41 pm ]
Well, looks like this thread has been HIJACKED! BACK TO THE ORIGINAL QUESTION PLEASE!!! :x
Author:  cb5331 [ Thu May 19, 2011 7:46 pm ]
Good luck with that. Welcome to the site! :lol:
Author:  frogger [ Fri May 20, 2011 4:22 pm ]
damn, Po Po got sum goodies.
Author:  da go get'er [ Fri May 20, 2011 4:44 pm ]
I been wanting to put a hydraulic Jack plate on my surface drive so that when I get high centered i can lower it another six inches to grab some water. If I ever get around to it I send you a review.
Author:  Mike W. [ Sun May 29, 2011 4:12 am ]
5200 RPM, 10 to 1 compression on Alcohol. When you hook up that turbo, you need to weld a piece of 1/4" steel plate to the front of the motor. That way, the pieces won't hit you in the back! :lol: :lol: :lol: :lol:
