It is currently Tue Jul 22, 2025 12:40 am
Reply to topic  [ 18 posts ]
 Onboard Battery Charger
Post Onboard Battery Charger
I'm looking for an onboard battery charger.. Heres what I plan on charging...
basically 3 12volt batteries, 1 cranking 12 volt and 2 12 volt wired in (series i believe) to run a 24 volt trolling motor. Can anybody suggest a good one...thanks in advance
Boone Barton Western KY
2015 Havoc 1650 MST .125
2015 35hp Hyper
Stock for now, goodies soon to follow.
Tue May 24, 2011 5:35 pm
Post Re: Onboard Battery Charger
Do you plan to always have 3 batteries in your boat. Thanks alot of extra weight aboard if your not fishing. If not then I wouldn't think you want a 3-bank. I have a Guest 1-bank just for my cranking battery which stays in the boat all the time. It gets plugged in between trips to ensure its hot. I swap out the TM battery for a smaller lawn tractor battery for back up when not trolling so I just use a regular chrger for them.
18x48 Charles Leonard / 36PD
Tue May 24, 2011 5:51 pm
1848 Cajun Performance GTR35
IF YOU AIN'T RUNNING WITH ME,,,,THEN RUN FROM ME!!!!!!!!!!!!
Tue May 24, 2011 7:00 pm
Yo dixieduck, you a yeti salesman? Can you get me a discount?
Gator tail
Tue May 24, 2011 8:17 pm
I just bought a minn kota 3 bank for my new boat I am building. I had a 2 bank minn kota in my last boat for 2 years and never had a problem.
20x60 homemade with twin Prodrives
JH Chopper (YLM)if I have time will make a SH
Wed May 25, 2011 6:13 am
IM'sO ~ You will never need 24V trollin' motor fo yore Pro-Drive MudMotorMachineThang ......
Wed May 25, 2011 9:53 am
After fishing with more and more guys, I hear the same thing. On board battery chargers are OK but your batteries will hold up better if charged with a regular charger after a few "on board charges". This is coming from guys that live for tournament fishing, take it for what it's worth.
Wed May 25, 2011 10:54 am
MMT Moderator
I always charge my batteries one at a time I have onboard chargers on the big boat but never trust them & always top off with a regular 2-4-6 AMP portable charger.
GTB 1860 w/ 2019 GTR40XD-HO
Wed May 25, 2011 11:29 am
Wed May 25, 2011 12:03 pm
I have already installed a 70lb thrust 24 volt trolling motor on my boat... I plan on keeping all 3 batteries in my boat at all time, when fishing for the trolling motor and during flooded timber hunting to run the vortex , mallard machines...etc....
and no I am not a yeti salesman just a happy customer
excuse me for my ignorance but do (3 bank chargers) mean for 3 batteries? and so on and so forth 2 bank for 2 batteries?
2015 35hp Hyper
Wed May 25, 2011 4:35 pm
Yes... 3 bank for 3 batts and 2 bank for 2 batts. I've had a Minn Kota 3 bank for 10 years with no problems.
Wed May 25, 2011 7:00 pm
I have a 2 bank Guest and it works great!
1856 Phowler Extreme w/ 36 PD Stage 1
Thu May 26, 2011 6:11 am
I have a two bank Minn kota and it works fine
Bayou Gun Runner
Thu May 26, 2011 1:42 pm
I gots a Black and Deckers with L.E.D. lites on it ......
Thu May 26, 2011 2:42 pm
well that was easy enough to understand (DOHHHHHH) anyways thanks guys for yalls onions.
2015 35hp Hyper
Thu May 26, 2011 5:04 pm
Ahhhh ~ Give it some mo time ..... There will be someone to come along in a few days that probly can give you mo help ..... Not alot of MMT'ers have much expirence with multiable battries .... you have asked a complicated type querston .... :lol:
Fri May 27, 2011 8:19 am
I use the guest three bank charger on mine. It works great I've been using that particular brand for at least twelve years with no issues. Batteries seem to last a lot longer with the inboard chargers. Sure is easy to park the boat and just plug it in and walk away. I also have the same setup on my mudboat (2 bank guest). And used it on one other center console boat as well (3 bank). I can't say anything about the other brands because this one has worked well for me so no need to switch.
Sat May 28, 2011 2:34 pm
A lot of their charging systems are configured differently on how to hook them up and how they charge. I have two Group 27 batteries with a 3-bank Guest charger. Mine has one charging curcuit (at a lower amp rate) for the starting battery with a green/red light and then two identical leads for the trolling motor batteries with one light between them.
I just hook up both of the trolling leads to my one trolling battery and get twice the charging amps. Since it seems like the 2 troliing motor banks on the charger are somehow related or inter-connected, it's worked great for me.
Sun May 29, 2011 2:30 am
Users browsing this forum: Google [Bot] and 100 guests
