It is currently Sat Sep 20, 2025 12:42 am
Reply to topic  [ 6 posts ]
 go devil flotation removal
Post go devil flotation removal
I'm in the process of buying a used 1644 go devil. The boats a 2001, based on some of the discussion i've read I'm assuming the flotation is "waterlogged". Has anyone removed the flotation personally that can give me some direction? Is there a way to check the condition of the flotation to see if it needs to be replaced? Any information would be much appreciated.
Wed Jul 06, 2011 9:47 am
Post Re: go devil flotation removal
The floor is simple, just drill out the rivets & remove it, the front deck & rear pods have to be cut on to remove the flotation. PM Robn1020 about it, he had his redone a couple years ago.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jul 06, 2011 9:50 am
According to some u will be putting yourself and others in danger if u remove it. I have been traumatized from reading those posts, don't know if I'll ever to get in my boat again.
Gator tail
Wed Jul 06, 2011 10:06 am
Wed Jul 06, 2011 10:12 am
It's not my theory, just passing along what was posted earlier
Gator tail
Wed Jul 06, 2011 1:34 pm
When u pull the floor up it will probably be painfully obvious that its water and fuel logged. I took a 2x6 and beat the strips out. Be careful its hot and you will need plenty of beer and or water. this is at least what i encountered
Thu Jul 07, 2011 9:58 pm
