It is currently Wed Jul 16, 2025 2:03 am
Reply to topic  [ 37 posts ]
 PRO DRIVE ?
Post PRO DRIVE ?
I JUST BOUGHT A DUCK HUNTER 15 (WRANGLER BOAT)
LOOKING AT PUTTING A PRO DRIVE 27 ON IT
HOW DO THEY DO ON OPEN WATER IN 2-3 FOOT CHOP
THANKS FOR ANY HELP
Wed Jun 15, 2011 10:19 am
Post Re: PRO DRIVE ?
Jus sayin...
Wed Jun 15, 2011 10:21 am
If you are in a 2-3 foot chop in a flat bottom mud boat, the motor won't be what you need to be concerned about...
The motor will work fine....
The boat, not so much...
Suggest you affix a empty clorox bottle to a rope and put in front of boat so you can find boat later when the chop lays down.... make sure you secure the other end of rope to the boat.
Also, make sure whatever you put in boat is floatable or in some sort of floating container including any people in boat.
Wed Jun 15, 2011 10:29 am
Post PRO DRIVE ?
2-3 feet ain't a chop!! Lol 6" is a chop!!
17x48 extreme stage 2 GTR
Wed Jun 15, 2011 10:31 am
MMT Moderator
My 1860 handles West Bay chop pretty good but it was a boat built for that purpose... It's a slowl crawl to get past 2-3' WAVES?!. If you want to get through it buy a DEEP V fiberglass and call it a day.
Flat bottoms are more for back lakes & marshes you can take them across open water but your going to beat the hell out of yourself. 2-3' in a 15' boat? I hope you have a life jacket. We average 10 people / yr around Galveston dying because of flat bottoms, north winds & in ability to swim. 2-3' lol it would be sporting to take my 22' Robalo through that!
GTB 1860 w/ 2019 GTR40XD-HO
Wed Jun 15, 2011 10:34 am
I got caught in almost 4' with my 14 footer one March, what made it even worse is when the wave comes down it put me on a stump a couple of times.
Definetly not somethin you want to do on a normal basis.
Wed Jun 15, 2011 10:45 am
I would look into getting a bay boat
Wed Jun 15, 2011 11:05 am
Tide pulled some decoys out and had to go out in Breton Sound in Venice w/ a stiff NE wind and 2'-3' waves. I was proud on my huntdeck and bilge pump. LOL You need a bigger rig if you plan to be in that kind of water and not a flat. Sory to sound unsupportive but don't want to read later of you being rescued by the coastguard. Good Luck!
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Wed Jun 15, 2011 11:56 am
most of the time will not be in that just concerend if the wind picks more than normal the 25 outbaord on it now does ok but i'm tired of using a push pole when i get into the mash (have to skirt edge of bay to get there)
finally got pic to work new to posting been reading site for a while
Wed Jun 15, 2011 12:20 pm
The Pro-Drive is not gonna match horsepower for horsepower to that outboard.
Wed Jun 15, 2011 12:26 pm
If u are constantly running heavy chop or big wave I would look into a bigger boat. Size of your motor won't mean a thing if your boat is sunk. We run some big water up here on the Mississippi river and I see guys in 16 foot flats that wont even go out when the wheather gets bad. I would look at like a 18 foot or bigger high sides and wide like 54-56. Maybe somthing like a semi v front to help cut the waves
Wed Jun 15, 2011 12:53 pm
Wed Jun 15, 2011 12:54 pm
i'm from pa hunt eastern shore alot starting to hunt southern nj
Wed Jun 15, 2011 12:57 pm
More on your ?.. the PD motor will work just fine in open water, they drive like a outboard what I would be carefull of is taking that boat where the PD will get u. That motor will take u places that boat should'nt go.....stumps, logs rocks.
Wed Jun 15, 2011 1:03 pm
main problem i run into is muck the tide goes out you dont notice till the the boat doesn't rock when the dog moves
Wed Jun 15, 2011 2:11 pm
Might want to have more bracing added to the transom of the boat, doubt it will handle the pro-drive on the back of it.
Wed Jun 15, 2011 2:12 pm
i was thinking of that also it's rated for a 30 which is @ 200lb (4 stroke)
Wed Jun 15, 2011 2:31 pm
2-3 footers in a 15' flat?
Wed Jun 15, 2011 3:10 pm
The 27 prodrive will weigh a good bit more than 200 lbs.
18'x54"CC Hanko/ 36PD
Wed Jun 15, 2011 4:53 pm
Fri Jun 17, 2011 12:47 pm
a good bit more=25 pounds to be exact
Fri Jun 17, 2011 12:53 pm
2' to 3' I run hooked up in my 16' flat with my 36 gtr and have no problems takes them like a champ don't even beat you that bad just skips along just saying dont be a puss.
stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Fri Jun 17, 2011 1:37 pm
That sportsman fab would be twisted up like a tin can!!! Mine would too.
Fri Jun 17, 2011 4:02 pm
he doesnt have a flatbottom. look up the boat, its a double v in the front, probably somethin like a modified v at the transom. id agree with fowlhabit, the motor will handle the boat, be careful of the boat handlin the motor.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Fri Jun 17, 2011 4:16 pm
these boats are built in ohio they run them on them big ponds up there
Fri Jun 17, 2011 4:18 pm
Dude that prodrive will rip that transom to pieces! It may only way 25 pounds more, but its gonna be slamming up and down. Especially trailering it down the road, you will see.
Fri Jun 17, 2011 4:57 pm
Sat Jun 18, 2011 11:11 am
Why even spend the money on a boat like that? I dont mean to be rude, but you would have prolly spent less on an aluminum hull. If you slap that motor on the back of that boat, one of two things are gonna happen.
1. The boat will crack or be useless after 5 trips in the back waters due to the power of the motor.
2. The transom is gonna rip off while gunning on it in the shallows, cause that boat is gonna hang shat big time.
If I was in your situation I would have gotten a 18-20 ft rig bout 48-52 inches wide and slapped at least a 35 MM on the back to handle the big water and the shallows plus the motor. This is a piss poor match up if Ive ever seen one. Your asking for serious heartache and trouble. One more thing you better invest in is a good marine radio and a strong bilge pump.
1648 war eagle with a 50 Tohatsu
Sat Jun 18, 2011 8:33 pm
Not to be sarcastic or rude , but guys that say they running 2'-3' chop in these flat mud boats must be the same guys that say they have 10 inch diks.
1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
Sun Jun 19, 2011 7:56 am
Profile YIM
I gave up mud motors
Sun Jun 19, 2011 9:18 am
12"
And I drive a pd and approve this message
driving a gd in ur lake
and i aprove this message
Sun Jun 19, 2011 9:31 am
I have been in a 2-3 rollers in my 1854 and I hope I dont have to do that again
Sun Jun 19, 2011 5:32 pm
Sun Jun 19, 2011 5:46 pm
Maybe one day I'll have one again
Sun Jun 19, 2011 7:54 pm
Sun Jun 19, 2011 8:03 pm
Users browsing this forum: Google [Bot] and 98 guests
