It is currently Mon Jul 21, 2025 7:49 am
Reply to topic  [ 37 posts ]
 Which Paint ?
Post Which Paint ?
Boys it's time to give the ol girl a makeover before this season! I don't really wanna rattle can it or walmart paint it.
What's a good paint that's not to expensive and holds up decent ?
Painting a 16x44 go devil!
Mon Jun 20, 2011 1:26 pm
Post Re: Which Paint ?
You can buy the paint go devil uses from them for 45 a gallon
Mon Jun 20, 2011 1:52 pm
Holler at CB He just painted his rig
Mon Jun 20, 2011 2:29 pm
Post Which Paint ?
Mon Jun 20, 2011 6:55 pm
I am in the process of painting mine and i have an 18 x 48 and i plan on using 2 gal
Mon Jun 20, 2011 7:09 pm
Check out duralux aluminum boat green. Do a search on here. I used it and am very happy with it
1848 Prodigy
35 GTR
Mon Jun 20, 2011 7:30 pm
x2, Duralux aluminum boat paint!
Mon Jun 20, 2011 7:43 pm
Mon Jun 20, 2011 7:53 pm
Mon Jun 20, 2011 7:54 pm
gotcha,like I said I can get that duralux real cheap down here compared to what I've seen people are paying in other places
Mon Jun 20, 2011 7:55 pm
I know man, almost half the price we paid.
Mon Jun 20, 2011 7:57 pm
I painted my 1644 with 1 gallon and have some left
Sent from my iPhone 5
1850 & 36pd
Mon Jun 20, 2011 8:21 pm
Post Which Paint ?
Mon Jun 20, 2011 10:05 pm
Or you can get the kem400 from sherwin williams. Thats what gatortrax uses. Its what I went with.
1850 & 36pd
Mon Jun 20, 2011 10:08 pm
Don't the kem400 need a primer too, though? I know when I talked to em about it, that was gonna end up costing me 2-3x more than I expected to spend. Good product though.
Sent from my Droid because I'm trying to be as cool as you someday.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jun 21, 2011 8:09 am
The kem does require a primer.
Tue Jun 21, 2011 8:16 am
Duralux M736 Aluminum Boat Paint Green. Requires no primer.
Here is where I got mine. ($79/gallon with free shipping) Used about a gallon and a half on a 18X48- BUT have steelflex on bottom and coming up sides about 5" and did not paint floor or deck as I am putting hydroturf in.
BUT....... DW posted up a place you can buy cheaper-not sure what shipping would be though....
http://www.bottompaintstore.com/duralux ... tag#nextag
If you are re-painting a boat....
SURFACE PREPARATION: The surface must be dry and free of grease, wax, dirt or other foreign matter. Scrape off all loose paint and dull any gloss with a light sanding or power brushing. Remove all dust with a cloth dampened with paint thinner and allow to dry.
Painted Surfaces: A small area should be tested for compatibility where over coating old paints.
Steel: Clean all bare areas to bright steel, Duralux Aluminum Boat Green will not lift Duralux Zinc Chromate Primer. Touch up with two coats of Duralux Zinc Chromate Primer. Top with two full coats of Duralux.
Aluminum: Touch up all bare areas with Aluminum Boat Green. Top with two full coats of Duralux Aluminum Boat Green.
Only comes in one color.
Duralux also sells some other colors but they require a primer. Link below to other colors.
Tue Jun 21, 2011 8:28 am
I didnt prime jack. Cleaned it good and started spraying. Its tough as nails too. Careful spraying in high heat. Its an industrial paint and dries very fast.
1850 & 36pd
Thu Jun 23, 2011 1:14 pm
Has anybody used the Parker duck boat paint that can be found on Cabelas Website?
Sun Jun 26, 2011 10:43 am
my son bought the camo stencil kit, w/ the parker paint. seemed to hold up pretty well. i was suprised seeing as that he could knock the camo off a sherman tank. but it did do good. good color corerage too.. didnt get much bleed through and went a long way
Tue Jun 28, 2011 11:00 am
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Tue Jun 28, 2011 11:13 am
It was right at 40 bucks a gallon I think. It's from a local place that deals with alot of commercial fisherman. Poydras hardware
Tue Jun 28, 2011 12:08 pm
40.00 is not bad at all. got an address? If I'm close by it next week I could pick up a gallon or two. Not sure where you stays or what area is local to you. Anybody else know of a deal on this paint?
Uncle J 1848 w/?
Tue Jun 28, 2011 1:19 pm
I can tell you where to get it for 80 bucks a gallon. Just be careful, they might ship it to your neighbor and it'll take you two weeks to find out where it went... :?
Tue Jun 28, 2011 1:25 pm
Duralux can be purchased at the Galvez Hardware in Ascension Parish for $50.00 Super nice folks over there. They have the aluminum boat green, rig grey, and white. Not sure if they will ship or the cost of it, but i can ask if you need me to.
Tue Jun 28, 2011 2:05 pm
pm sent
Tue Jun 28, 2011 2:07 pm
Tue Jun 28, 2011 2:08 pm
Yessir you would be correct on that. I didn't price anything but the aluminum boat green. Sorry to not post that too clear.
Tue Jun 28, 2011 2:41 pm
I've painted a rig with Parker paint and it was good and cheap... we did a Nat gear boat in Lock,Stock and Barrel Boat paint that Matched Natgear perfect and was by far the best paint and held up great...
18x52 Widow Maker Hull being pushed by a HD 5500 BAMF...
Tue Jun 28, 2011 9:57 pm
Uncle J 1848 w/?
Wed Jun 29, 2011 6:15 am
Thu Jun 30, 2011 1:39 am
Uncle J 1848 w/?
Thu Jun 30, 2011 4:47 am
Thanks Earl, that looks real nice. I think the nat gear is pretty much the best pattern for where I hunt. Any chance you remember which stencil's you used?
Thu Jun 30, 2011 1:27 pm
Man, I've bought 3-4 gallons of Duralux Dead Grass Green for $24.95 over the last several years at the local True Value---either you guys are paying way too much or I've found a helluva deal!
This paint says to prime first but most everything we've painted with it we just cleaned and prepped well and it wears like iron--tough paint. We even painted a jon boat one time the night before opening day and had a electric smoker element and a propane burner under the boat to try to get it warm enough to dry--still looked good 3-4 years later(not advised but hey, we got the job done!)
We've painted boats, shotguns, boat trailers, a mini truck, and various other things with it--even considering painting my FJ60 dead grass green! Rolled, brushed, and sprayed with good results.
Sun Jul 03, 2011 10:24 pm
Mon Jul 04, 2011 8:49 am
dead grass green and aluminum boat green are two different paints. The aluminum boat green is a more expensive paint
Mon Jul 04, 2011 8:54 am
Gotcha. The DDG is still cheaper and tough as hell.
Mon Jul 04, 2011 12:49 pm
Users browsing this forum: No registered users and 113 guests
