huntdeck and catwalk questions
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=20058
Author:  willett [ Fri Jul 15, 2011 3:17 pm ]
Post subject:  huntdeck and catwalk questions
say a gator tail boat, what is the typical length of a hunt deck?
How tall is it?
how exactly is the motor mount braced?
Catwalks - what are the typical width? 12" ?
Author:  WestEndAngler [ Fri Jul 15, 2011 3:21 pm ]
Post subject:  Re: huntdeck and catwalk questions
Well the transom (inside hull) will come up to 20" then there is about a 6-8" drop to the hunt deck floor and off the back of the hunt deck you have your motor / transom that comes up & has the proper angle etc. Mine was built w/ hunt deck from the start so not sure on bracing sorry.
Author:  WestEndAngler [ Fri Jul 15, 2011 3:25 pm ]
according to Gator-Tail's site...
6" 6061T6 Channel For Transom Bracing
Author:  willett [ Fri Jul 15, 2011 3:30 pm ]
thanks for the info and yea i knew about the channel for the initial transom bracing i just meant how exactly is the peice sticking up for the motor to mount to on the back of the hunt deck
Author:  WestEndAngler [ Fri Jul 15, 2011 3:55 pm ]
not sure what pics I have on my "rig review" but check the link in my signature...
Author:  Sko [ Fri Jul 15, 2011 4:04 pm ]
Hunt deck is 16" long.catwalks are what ever you want. Most are 5-6".
Author:  willett [ Fri Jul 15, 2011 4:20 pm ]
how wide is the peice the motor hangs on? 12"
still how exactly is it braced? just the channel welded out and thats it or what
on a bot without huntdeck you see gussets on the back corners and that along with channel across and down the transom is the bracing for impacts. Thats why im wondering about it the peice sticking up above the hunt deck
Author:  Sko [ Fri Jul 15, 2011 4:29 pm ]
It is 6" channel across and 2 coming up 8-6" taller about a foot apart from outside to outside. When you tie in all the plate on the hunt deck it is plenty strong enough. It is tied into the sides , transom, and false transom . It is actully tied in in more area than a regular transom
Author:  willett [ Fri Jul 15, 2011 5:24 pm ]
makes sense thanks for the clarification
