Riverrat86
 info on phowler boat
i am lookin at getting a phowler but i dont like the runners on the bottom of the boats seems like they will just hang up on stuff. wondering if anyone runs one of the basic flats on how the like it and how bad the runners mess up the perfromace i mean if it helps y dont they put it on they other boats? thanks
Mon Jul 11, 2011 5:22 pm |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
 Re: info on phowler boat
Talk to Bubba or Paul at Phowler, they will give you the pros and cons of runners. They will build you one with or without the runners.
I don't have runners on mine. It turns a little differently than a regular jon boat, but once you are accustomed to it, it is no big deal.
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
Mon Jul 11, 2011 5:44 pm |
Riverrat86
thanks i was just wonderin if any one runs one handling the boat is not the problem just i wanted one with out the runners came up a a good deal and was just curious how it performed. but i will for sure talk to them and thanks again
Mon Jul 11, 2011 6:03 pm |
gauge306
Joined: Sun Oct 24, 2010 4:23 pm Posts: 38 Location: Southeastern Wisconsin
They will build it either way...got mine without runners.
_________________ 1856 Phowler Extreme w/ 36 PD Stage 1
Mon Jul 11, 2011 9:08 pm |
balloon-knot
Joined: Wed Jan 14, 2009 9:05 am Posts: 398 Location: Prairie du Chien, WI
It all depends on the style of running you do, just like Cut said.
It really is just personal preference.
_________________ Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Tue Jul 12, 2011 10:39 am |
Riverrat86
thanks for everything i had my mind pretty much made up but i just wanted to make sure. i will get the boat without the runners better for what i run.
Tue Jul 12, 2011 6:40 pm |
Short On Cache
I run a Phowler with the runners. It turns much tighter then the boats without. The only con is if you get on a stump you gotta run it out, it usually wont slide off.
_________________ The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown Greater love has no other than this that he lay down his life for his friends. John 15:13
Fri Jul 15, 2011 12:44 pm |
westwind
Like the idea of external runners for the purpose of keeping the bottom more rigid. Hated having square runners.
How about round tubing split in half or thirds? You get the bottom more rigid without the sharp hanging up edges. I know I don't need training wheels and could care less about the turning issue but liked the added strength for stump bashing.
Paul, if this turns into the "large drain plug, episode #2", I apologize in advance.
Sat Jul 16, 2011 8:05 am |
westwind
Just to make it really complicated,I want two or three rounded, shallow runners and at the transom I want a 6' runner out near the side walls and in between every other runner. The short runners have to be split out of tube like a wedge, thinnest from the front and tapering down to protect the last section of boat ahead of the transom.
Might as well make the bottom 3/16, big drain plug, 62.5 wide by 19 3/4 long 24 3/4 inch sides it has to run 40 mph deep water and I have to have it by last Tuesday. Also will need a blind that works like Harry Potters cloak of invisibility. Can you do all that, lol!
Sat Jul 16, 2011 8:14 am |
