It is currently Tue Jul 29, 2025 5:24 am
Reply to topic  [ 20 posts ]
 GD Hull Owners
Post GD Hull Owners
Was putting in some hydroturf over the weekend and was thinking of cutting open the bow and ripping out all the old flotation in there. It's all pretty much dry rotted, so I don't think I'm getting anything out of it. Took out the floor flotation about 3-4 years ago.
Pros and cons of doing?
Was thinking of cutting out the bottom panel and just leaving the top deck. Seems pretty stable and shouldn't cause any structure weakness?
18x48 Brother Breaux -- 36HP ProDrive
Mon Mar 21, 2011 2:07 pm
Post Re: GD Hull Owners
I did the same thing to my hull. Here are some pics. I had some canvas covers made to snap over the holes i cut.
Mon Mar 21, 2011 2:22 pm
alright man I just tried for about 15 min to find you the old review someone had on here where they took the foam out of their boat.... but I couldnt find it!
anyway Im sure someone will chime in but if I remember correctly the easiest way to remove that foam is with a pressure washer :shock: :lol: Im sure its super messy but from what I remember it does the job fast! If I somehow come acrosss the thread Ill post the link on here.... good luck!
Sold my Uncle-J and my PD so Fuc* Y'all!!!!!.
"THE EDGE: There is no honest way to explain it because, the only ones who know where it is have gone over. The others... the living, are those who've pushed their control as far as they felt they could handle and then pulled back or slowed down........BUT the edge is still out there...."
Mon Mar 21, 2011 2:23 pm
A pressure washed and a shop vac. I didn't use that method, but ive heard thats the way to go. I used the cut and pull method!!
Mon Mar 21, 2011 2:27 pm
Mon Mar 21, 2011 2:39 pm
Smoke - I was thinking of cutting out the boxed in area of the photo below. Is there a reason why you went with the two access holes?2011-03-21_153717.jpg
Mon Mar 21, 2011 2:40 pm
Originally, I had 2 6 gal tanks mounted under there. I figured one hole for each tank, plus the piece in the middle would add some strength when bowfishing 2 people on the deck. Not sure if its needed or not, but that was my thinking.
Mon Mar 21, 2011 2:49 pm
This the one? viewtopic.php?t=9796
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 21, 2011 6:55 pm
That's the one... thanks Camo
Tue Mar 22, 2011 11:07 am
I did it on mine also. I went the same route as SmokeEater829 and cut two access hatches. Pressure washer and a large shop vac is definitely the way to go. I'd recommend 3000 psi minimum on the pressure washer also. I used a 2700 psi pressure washer. It worked, but a little more would have been nice. Wear eye protection and expect to get covered in foam pieces. I have the extended front deck on my GD. The portion in front of the extended deck pops when someone heavy stands on it. It didn't do that with the foam supporting it underneath.
Nathan
1656 Go-Devil with a Mud Buddy 27 Mini.
Tue Mar 22, 2011 12:10 pm
Mine was already done when I bought it, but the front was completely removed and was replaced with 1/8" diamond plate welded flush with the gunnels with a shorter piece broke into a 90 at the rear for strength. Never had an issue with support or "popping". Didn't look as clean as Smoke's but had plenty of storage & was probably alo easier to clean the foam out of.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Mar 22, 2011 12:19 pm
I took the foam out of my side float panels and had a couple lids fabbed up for em.Made a couple nice storage/gunboxes.
Tue Mar 22, 2011 9:01 pm
Burch, post up some pics if you got any.
Tue Mar 22, 2011 9:16 pm
All I have is some phone pictures and Im not computer literate to figure out how to send em.If anybodys willing I can send em to ya and you can post em up.
Tue Mar 22, 2011 9:25 pm
Here are the pictures that Burch made.
Thu Mar 24, 2011 10:46 am
Last two...
Thu Mar 24, 2011 10:47 am
Finally had sometime over the weekend to start and finish the project. I didn't have the balls to cut out the flotation in the back so maybe another day. While I had all the floors up I re-ran all my wires and fuel line in the runners and added a fuel/water separator to boot.
The Cut:
The Clean-out:
The Carnage:
Added additional braces and decked with alum panel then hydroturf.
Tue Jul 26, 2011 11:37 am
damn good job man! what speeds you geting with that rig?
Tue Jul 26, 2011 11:48 am
Nice "facelift" - just in time for hunting season too ! ! !
Eat - Sleep - Hunt ! ! !
Tue Jul 26, 2011 11:52 am
Tue Jul 26, 2011 12:00 pm
Users browsing this forum: No registered users and 103 guests
