It is currently Wed Jul 23, 2025 2:22 am
Reply to topic  [ 8 posts ]
 Homade Blind Qusetion?
Post Homade Blind Qusetion?
Has anyone used aluminum instead of galvinized pipe when buiding your pop-up blind. I was wondering if aluminum would be strong enough or would it sag to much on a 16'-17' span. If anyone has used aluminum, what size? Thanks for the help!!
Mon Aug 29, 2011 7:53 pm
Post Re: Homade Blind Qusetion?
:? I thought everyone used aluminum. Every one I've ever seen has been aluminum, including factory built blinds. Galv pipe seems like it'd be super heavy & rust.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Aug 29, 2011 7:58 pm
i use emt conduit, lightweight and ALOT cheaper than the aluminum. you can almost buy all the emt you would need for the price of a stick of aluminum
Mon Aug 29, 2011 8:01 pm
I used conduit. Works fine. Just painted it. I'm sure its a lot cheaper than aluminum.
1754 Xtreme 35 GTR Stage 1
Mon Aug 29, 2011 8:02 pm
Put yer face in the myrtles.
Mon Aug 29, 2011 8:08 pm
ive had several made of emt and they worked fine. wipe down with vinegar and paint will stick good, if not it will pop off. i have an aluminum one now, just because a friend gave me the alum pipe. 3/4 inch and works fine too. its the camo not the frame that makes a blind work or fail. but make it simple and easy to put up
Tue Aug 30, 2011 9:26 am
Ive built all of mine out of emt. If you dont want it to sag just buy a smaller diameter and slide it into your rails.
1542 War Eagle with 25hp GDLT
Tue Aug 30, 2011 1:21 pm
Thanks for the info!
I should be ok from here!
Tue Aug 30, 2011 6:10 pm
Users browsing this forum: Google [Bot] and 81 guests
