It is currently Tue Jul 22, 2025 7:19 pm
[ 6 posts ] |
Welding Aluminum Plate on Phowler rear pod
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
I want to have someone weld an aluminum plate, with 2 conduit receivers, on the rear pod for a grab bar on a Phowler 1848. Since the pod has a block of floatation, is there any concern with the floatation catching fire since the aluminum on the pod is going to have to get heated up pretty good.
Thanks for any input.
_________________ Phowler Extreme 1848 with 36PDFPR
Sat Sep 10, 2011 12:40 pm |
mcnemar1982
Joined: Mon Jan 19, 2009 4:03 pm Posts: 2216 Location: Walker, Louisiana
 Re: Welding Aluminum Plate on Phowler rear pod
Tell your welder to not blow holes thru the hull and you should be fine.
_________________ Ideas not coupled with action never become bigger than the brain cells they occupied.
Owner DEEP SOUTH CUSTOM BOATS (225) 252-2700 Good boats ain't cheap, Cheap boats ain't good!
Sat Sep 10, 2011 1:27 pm |
mudder
Thanks Mc. He just said the aluminum will get very hot and wanted to make sure. But it is closed cell foam block which should be better than loose foam, I hope.
Sat Sep 10, 2011 2:08 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
dont do it!! closed cell foam is highly explosive!!!!
Sat Sep 10, 2011 2:26 pm |
riverratdm84
Joined: Fri Jul 30, 2010 3:15 pm Posts: 701 Location: pella, ia
i tried burning it out of a boat that i scraped out. it burned an then smothered out quickly. I would have a fire extinguisher handy but should be ok.
Sat Sep 10, 2011 4:51 pm |
autogateman
I really was just joking. It is flammable though like he^ said.
Sat Sep 10, 2011 6:13 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 160 guests |
