Welding Aluminum Plate on Phowler rear pod http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=21918 |
Author: | mudder [ Sat Sep 10, 2011 12:40 pm ] |
Post subject: | Welding Aluminum Plate on Phowler rear pod |
I want to have someone weld an aluminum plate, with 2 conduit receivers, on the rear pod for a grab bar on a Phowler 1848. Since the pod has a block of floatation, is there any concern with the floatation catching fire since the aluminum on the pod is going to have to get heated up pretty good. Thanks for any input. |
Author: | mcnemar1982 [ Sat Sep 10, 2011 1:27 pm ] |
Post subject: | Re: Welding Aluminum Plate on Phowler rear pod |
Tell your welder to not blow holes thru the hull and you should be fine. |
Author: | mudder [ Sat Sep 10, 2011 2:08 pm ] |
Thanks Mc. He just said the aluminum will get very hot and wanted to make sure. But it is closed cell foam block which should be better than loose foam, I hope. ![]() |
Author: | autogateman [ Sat Sep 10, 2011 2:26 pm ] |
dont do it!! closed cell foam is highly explosive!!!! |
Author: | riverratdm84 [ Sat Sep 10, 2011 4:51 pm ] |
i tried burning it out of a boat that i scraped out. it burned an then smothered out quickly. I would have a fire extinguisher handy but should be ok. |
Author: | autogateman [ Sat Sep 10, 2011 6:13 pm ] |
I really was just joking. It is flammable though like he^ said. |
