It is currently Thu Dec 18, 2025 3:57 pm
Reply to topic  [ 10 posts ]
 Need Some Advice
Post Need Some Advice
I found a boat that I might buy. Not sure if the boat an motor are a good match.
The boat is a 16 foot Express with a 36 hp prodrive on it. The motor only has 18 hours, and is a 2008 with manual revers and power trim and tilt. The boat also only has 18 hours and it sits on a galvanized trailer.
I know the boat isn't ideal but would this work ok?
Thu Oct 20, 2011 8:41 am
Post Re: Need Some Advice
If it has a Mod Vee pass on it. I thought you was going to Let Brother build you a boat? My personal opinion 16' is too short!
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Oct 20, 2011 9:05 am
Yeah was as thinking the same.
I want to get brother to build my boat but the money just hasn't showed up like I thought. So i been looking at used boats.
I do have a question you might be able to answer. If brother build a 1748 with extended front deck, driver box, and 5ft gun box how would a 30hp outboard push it? I got a new 30hp tohatsu 2 stroke at the house and i was thinking about getting the boat and putting the 30 on it, until i got the cash for the prodrive.
Whats your thoughts? Not enough motor?
Thu Oct 20, 2011 9:18 am
That 30 hp will push it fine. But if your gonna get a boat built I would go 18 ft. It won't cost you any more and you will have a much better performing rig when you do get that PD.
Thu Oct 20, 2011 9:22 am
Bayou Surface Drive
337-351-0362
Thu Oct 20, 2011 9:40 am
Ok so here is the next issue
I want 21 inch sides, and if I'm not mistaken that would mean i need a prodrive with the long shank but the Outboard I have is a short shaft. How could I make this work? What kind of speeds would i be looking at with the 30hp Outboard?
Thu Oct 20, 2011 10:26 am
You might want to do alot more homework ;)
Thu Oct 20, 2011 11:17 am
Have it built for a short transom. But let Brother know that you will be eventually putting a tall transom motor on it, and he can build it where he can drop in a piece of well braced aluminum and weld it in place to make it a tall transom.
Thu Oct 20, 2011 11:30 am
I have done plenty of homework.
Would a Jack Plate work on a mmt or would that be to much banging around for it?
Thu Oct 20, 2011 12:05 pm
Work - maybe if the motor didn't contact the transom when it is lifted
But not an ideal setup at all for a PD - they like to be close to the transom
and like the transom to have a "hard" rear edge not a rolled rear edge....
Also each MM has a different "ideal" transom height and angle - they are
not standardized at all - so your builder needs to build for a specific MM....
Eat - Sleep - Hunt ! ! !
Thu Oct 20, 2011 12:18 pm
