Podcast
Joined: Fri Dec 09, 2011 12:33 pm Posts: 1363 Location: Friggin cold up here
 Electrical distribution
Gonna be wirin up da new boat soon as it gets here. Any a y'all ever run a single main power en ground line to da switch panel and lines out from der? I really don't wanna run individual lines fer each part from my battery to my switch en back out again. If so, what kinda switch panel ya use?
_________________ Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here" 23GTR stage 2 by Calen pushin a 1746 Kliebert
Wed Apr 11, 2012 10:26 am |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
 Re: Electrical distribution
I really dont understand your question but here is the panel that I have used... worked great... http://www.google.com/products/catalog? ... KYBEPMCMAE
_________________ WC 1848 Bateau w/ 36 PD FPR
Wed Apr 11, 2012 10:35 am |
Podcast
I'm lookin ta run just a single power and ground wire from da front a da boat to da rear where my switch panel will be. I wanna split da power from der ta each individual switch. I'm wonderin if anyone makes a switch panel dat ya can hook just them two wires ta and it sends power ta each switch on dat board. Otherwise I gotta split it before da board ta each switch or worst case run a wire for every switch from da battery back which would suck.
Wed Apr 11, 2012 10:39 am |
The Shafer
judging by the way you talk/type I wouldn't touch anything electrical if I were you.
Wed Apr 11, 2012 10:41 am |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
_________________ 35 GTR - 1754 Extreme
Wed Apr 11, 2012 10:42 am |
Podcast
Wed Apr 11, 2012 10:52 am |
DuckHunterF250
Joined: Tue Jun 29, 2010 8:32 pm Posts: 1801 Location: atlanta texas
_________________ 1854 DeadFowl custom boat 35 GTR "The bitterness of poor quality remains long after the sweetness of low price is forgotten."
Wed Apr 11, 2012 11:00 am |
CLICKSTER
It's to or too! Ta isn't even a word, it's an abbreviation.
Wed Apr 11, 2012 11:03 am |
BoatDR
1) there are dozens of manuacturers that make pannels which are pre wired. Some even come with individual breakers or fuses for each switch too. Like this http://bluesea.com/category/105/84/productline/1202) But there arent any (good marine ones that is) that have a bus bar made onto them. in that case, get one of these and mount it a couple inches away from the switch pannel, and jump all your negatives off of it. http://bluesea.com/category/82/353) how big of a switch pannel are you looking for (how many switches)?
Wed Apr 11, 2012 11:06 am |
Podcast
Wow. Dis chit is really hard I guess.
Ok, I'll break er down.
I don't wanna have ta run a power wire ta every freakin switch on da panel. I wanna run just one power wire and one ground wire to da switch panel and split it from der.
So, my question is, does anyone know if a switch panel is available that will connect a single power and ground wire and then distribute da power to all da switches from der?
Tried ta make dat post clear as possible. I know my lingo's a bit phucked up but dat should do er.
Wed Apr 11, 2012 11:07 am |
Podcast
Wed Apr 11, 2012 11:09 am |
BoatDR
Wed Apr 11, 2012 11:19 am |
Podcast
Thanks again. Looks like dats the route I'll be takin. At least I know they don't offer one pre installed on a panel. Have ta set it up separately.
Sent using pony express
Wed Apr 11, 2012 11:25 am |
DirtNasty
Joined: Fri Jun 03, 2011 7:55 am Posts: 221 Location: Bullard, TX
This is the one that I used. You can just run one power wire to switch. It is also well built and low profile and doesnt have the toggle switches that can get broken off. Also backlit with leds. There is a video on istallation too got mine on clearance at academy for 40 bucks http://www.jamestowndistributors.com/us ... itch+Panel
Thu Apr 12, 2012 8:42 am |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
Podcast aren't you 17?
_________________ You have your whole life to be an idiot, take a day off!
Thu Apr 12, 2012 12:11 pm |
Podcast
Thu Apr 12, 2012 12:30 pm |
duckduckboom
On tos you age said 17
Thu Apr 12, 2012 12:44 pm |
Podcast
Sorry fer dat DDB, 30's da age.
Thu Apr 12, 2012 4:05 pm |
duckduckboom
You say your "lingo" is messed up but you have posted on another thread in legible English
Thu Apr 12, 2012 4:20 pm |
cb5331
 Re: Re: Electrical distribution
Thu Apr 12, 2012 4:21 pm |
Podcast
Thu Apr 12, 2012 5:54 pm |
