Electrical distribution http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=28344 |
Author: | Podcast [ Wed Apr 11, 2012 10:26 am ] |
Post subject: | Electrical distribution |
Gonna be wirin up da new boat soon as it gets here. Any a y'all ever run a single main power en ground line to da switch panel and lines out from der? I really don't wanna run individual lines fer each part from my battery to my switch en back out again. If so, what kinda switch panel ya use? |
Author: | The Shafer [ Wed Apr 11, 2012 10:35 am ] |
Post subject: | Re: Electrical distribution |
I really dont understand your question but here is the panel that I have used... worked great... http://www.google.com/products/catalog? ... KYBEPMCMAE |
Author: | Podcast [ Wed Apr 11, 2012 10:39 am ] |
I'm lookin ta run just a single power and ground wire from da front a da boat to da rear where my switch panel will be. I wanna split da power from der ta each individual switch. I'm wonderin if anyone makes a switch panel dat ya can hook just them two wires ta and it sends power ta each switch on dat board. Otherwise I gotta split it before da board ta each switch or worst case run a wire for every switch from da battery back which would suck. |
Author: | The Shafer [ Wed Apr 11, 2012 10:41 am ] |
judging by the way you talk/type I wouldn't touch anything electrical if I were you. |
Author: | CJB [ Wed Apr 11, 2012 10:42 am ] |
Author: | Podcast [ Wed Apr 11, 2012 10:52 am ] |
Author: | DuckHunterF250 [ Wed Apr 11, 2012 11:00 am ] |
Author: | CLICKSTER [ Wed Apr 11, 2012 11:03 am ] |
It's to or too! Ta isn't even a word, it's an abbreviation. ![]() ![]() |
Author: | BoatDR [ Wed Apr 11, 2012 11:06 am ] |
1) there are dozens of manuacturers that make pannels which are pre wired. Some even come with individual breakers or fuses for each switch too. Like this http://bluesea.com/category/105/84/productline/120 2) But there arent any (good marine ones that is) that have a bus bar made onto them. in that case, get one of these and mount it a couple inches away from the switch pannel, and jump all your negatives off of it. http://bluesea.com/category/82/35 3) how big of a switch pannel are you looking for (how many switches)? |
Author: | Podcast [ Wed Apr 11, 2012 11:07 am ] |
Wow. Dis chit is really hard I guess. Ok, I'll break er down. I don't wanna have ta run a power wire ta every freakin switch on da panel. I wanna run just one power wire and one ground wire to da switch panel and split it from der. So, my question is, does anyone know if a switch panel is available that will connect a single power and ground wire and then distribute da power to all da switches from der? Tried ta make dat post clear as possible. I know my lingo's a bit phucked up but dat should do er. |
Author: | Podcast [ Wed Apr 11, 2012 11:09 am ] |
Author: | BoatDR [ Wed Apr 11, 2012 11:19 am ] |
Author: | Podcast [ Wed Apr 11, 2012 11:25 am ] |
Thanks again. Looks like dats the route I'll be takin. At least I know they don't offer one pre installed on a panel. Have ta set it up separately. Sent using pony express |
Author: | DirtNasty [ Thu Apr 12, 2012 8:42 am ] |
This is the one that I used. You can just run one power wire to switch. It is also well built and low profile and doesnt have the toggle switches that can get broken off. Also backlit with leds. There is a video on istallation too got mine on clearance at academy for 40 bucks http://www.jamestowndistributors.com/us ... itch+Panel |
Author: | duckduckboom [ Thu Apr 12, 2012 12:11 pm ] |
Podcast aren't you 17? |
Author: | Podcast [ Thu Apr 12, 2012 12:30 pm ] |
Author: | duckduckboom [ Thu Apr 12, 2012 12:44 pm ] |
On tos you age said 17 |
Author: | Podcast [ Thu Apr 12, 2012 4:05 pm ] |
Sorry fer dat DDB, 30's da age. |
Author: | duckduckboom [ Thu Apr 12, 2012 4:20 pm ] |
You say your "lingo" is messed up but you have posted on another thread in legible English |
Author: | cb5331 [ Thu Apr 12, 2012 4:21 pm ] |
Post subject: | Re: Re: Electrical distribution |
Author: | Podcast [ Thu Apr 12, 2012 5:54 pm ] |
