Pluck IT
Joined: Sat Apr 16, 2011 11:55 am Posts: 57 Location: Youngsville, LA
 Prodrive boat owners?
Has anyone cut the extra metal off in the back of the boat? If so how did it act after? I was considering cutting off the middle section and leaving the side areas about 6" on both sides. I know it probley acts as a trim tab would but wasnt sure if it has been done or not. seems like it would do even better in reverse if it wasn't holding so much water rite there.
_________________ 18x54 ProDrive boat with 36 FPR ProDrive Mikuni, MM 2x w/baffles Wild 'n Out!! Tear'n CHIT UP!!
Wed Apr 11, 2012 3:07 pm |
Will
 Re: Prodrive boat owners?
Your not given it enough gas, the back of mine comes out of the water in reverse.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Wed Apr 11, 2012 6:20 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Wed Apr 11, 2012 6:40 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
Trim it off as u need. Not gonna make much difference. U need to give it a lil more gas in reverse.
_________________ 18'x54"CC Hanko/ 36PD
Wed Apr 11, 2012 7:28 pm |
Pluck IT
so I guess the verdict is not ragging it enough in reverse  well I was just wondering. If I decide to get a wild hair I may cut out the middle section. let yall know if i do.
Thu Apr 12, 2012 2:52 pm |
pooldoo73
Pretty much. If you get in a place that u need to back out of, U likely need to put it to the limiter to get it moving backwards. At least that is my experience.
Thu Apr 12, 2012 7:01 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Thu Apr 12, 2012 7:08 pm |
Pluck IT
I agree and do give it the juice when needed I was just thinking that the lip on back holds a lot of water causing drag. I get out of tough spots. was just thinking about reducing some of that drag.
Fri Apr 13, 2012 8:46 am |
Will
I bent mine up by accident and it had a jet of water coming up in that spot that was hitting the front of the motor and splashing back. I had to straighten it back so I wonder what would happen if you removed a bigger section? I think you would get a rise in the water at the prop and mess with the motor pitch when your on plane.
Fri Apr 13, 2012 11:03 am |
mizzippi jb
does the back of a pd boat have a little shelf like a big trim tab or something? My boat has a cut transom, really helps in reverse. Its like a little mini rake. Some folks say it hurts performance with the PD motor, but I can't see much in the way of hindering it.
Fri Apr 13, 2012 6:08 pm |
Pluck IT
yea it has shelf on the back that just collects water, but I can also see it as a long trim tab. My buddy has the mini rake you talk about around his whole boat and cuts just rediculous doughnuts with his PD, but with the back raked like that he gets on step in reverse no problem and he is a big fella in the back of the boat. I can see where it could mess with the way the boat planes out or the torque from the motor that is why I got on here to ask it it has been done yet. Its alot easier to take that lip off than put it back
Mon Apr 16, 2012 6:29 am |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
_________________ 18x48 Charles Leonard / 36PD
Mon Apr 16, 2012 7:32 pm |
mizzippi jb
Tue Apr 17, 2012 2:50 pm |
