It is currently Fri Sep 19, 2025 8:02 pm
[ 7 posts ] |
Opinion on Alumacraft 1648 Mod V ?
Turbo
Joined: Sun May 06, 2012 7:57 am Posts: 4 Location: Central MN
Looking at a 09 rivited alumacraft 1648 mod v and putting a 27 or 35hp long tail on it. Would it completely plow water or would i be ok. I know it's not a heavy duty hull but the price might be right. Thoughts?
Fri May 18, 2012 4:49 pm |
Podcast
Joined: Fri Dec 09, 2011 12:33 pm Posts: 1363 Location: Friggin cold up here
By yourself ya may be ok.
_________________ Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here" 23GTR stage 2 by Calen pushin a 1746 Kliebert
Fri May 18, 2012 6:19 pm |
3peckeredbilly
 Re: Opinion on Alumacraft 1648 Mod V ?
Better run the 35. You'll be ok with yourself but once you start addin all your heavy friends it'll plow.
Where in central Minnesota you at?
_________________ "Just because I don't respond doesn't make me dumb, just waiting for the retards to quit babbling."
Fri May 18, 2012 6:20 pm |
Turbo
How is the performance affected with a mod v vs a standard jon?
btw, i'm just north of St. Cloud.
Fri May 18, 2012 7:50 pm |
3peckeredbilly
With a jon front end you will plane out better,(faster) with a long tail. It will spread weight out across whole boat bottom. Mudmotors are not made to run on mod-v hulls. U'll be much happier with a flat. Buddy had a 27 surface drive on a 1648 riveted jon and it did well.
From the Owatonna, Faribault area.
Sat May 19, 2012 6:09 pm |
torrey w
Joined: Thu Oct 13, 2011 8:21 pm Posts: 42 Location: mankato mn
In running a 23 mudd buddy sd on a alumacraft 1648 jon flat i like it goes 27 mph just me and gear
Sun May 20, 2012 8:24 pm |
outdoor freak
Joined: Fri Sep 02, 2011 10:06 pm Posts: 99 Location: michigan
Well learn from my mistakes , I stared off with a 23 sd on a 1448 tracker hull the boat it was welded and it was extremely light i figured that the 23 would move the boat pretty fast nope i was wrong it would get on plane and run about 18 mph 12-14 plowing water with 2 guys . After all the disapointment i spent the money and had a mud hull made and when i went and got it i was seriously worried ,the boat was alot heavier then the tracker and i mean alot heavier .The boat i had built has round chines a smooth flat bottom and the correct transom .the new boat with the sam motor a foot longer and way heavier gets on plane faster and is running speeds alot faster. Just me 25 mph, 2 guys 22 ,3 guys 18 but with 3 guys it doesnt get on plane like a bullet but it does get up on step .
Buy a boat made to run the motors and dont waste your money on a boat made for an outboard
Sat May 26, 2012 11:51 pm |
[ 7 posts ] |
