| round or square chimes http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=3145 |
| Author: | n.o.yat [ Mon Jul 13, 2009 6:55 am ] |
| Post subject: | round or square chimes |
what is the best on a boat, round or square chimes? and what is the purpose for each? |
| Author: | Gigafowl [ Mon Jul 13, 2009 7:54 am ] |
| Post subject: | Re: round or square chimes |
Based upon your other post WTB 23/27 LT.... Here is my opinion on round versus square... Assuming you wanna go 20mph solo and 18mph double... A GoDevil 18x38 round chine was designed to get the most speed with the 20hp class motor with a load - the round and narrow design "cuts" through the water and veggies - also turns sharper without sliding A square chine - would float shallower - but slide significantly in the turns at WOT - advantage would be over rocks, oyster beds or sand bars A third choice is available in the tapered chine like the GoDevil 16x48 which is a hybrid that slides a little at WOT but floats shallower than the round chine For that motor IMO the GD 18x38 or the GDSD 16x48 would be the two designs to compare and choose from - they both have ample floatation too in case "stuff happens" - that is my opinion anyway |
| Author: | n.o.yat [ Mon Jul 13, 2009 8:29 am ] |
i have a 16 ft. go-devil boat w/ round chimes. i want a rig to go in the swamp by my house. i want to put a 23 on it. do you think this would make a good combination? i am not sure if mine are tapered. they look rounded to me. |
| Author: | POKER1 [ Mon Jul 13, 2009 1:09 pm ] |
A square chine can do everything a round chine can and then some. The argument of sliding in turns becomes a mute point with a little stick time and the average owner will NEVER be running fast enough for it to be a concern anyway. We talking lawn mower engines running on average 25-28 mph for the biggest stock motors out right now. The only advantage I see for a round chine argument is if your having to push the boat to turn it around. But I have FPR so what do I know???????? |
| Author: | Full Throttle [ Mon Jul 13, 2009 1:23 pm ] |
I've run square and double tapered. The square sits alot higher in the water. I was concerned about the sliding aspect as well, but it is no big deal. You just got to learn to drive it, thats all. I guess I'm not in situations that often where I need to be WOT making a turn. I would never go back to a double taper or round now that I have a square. |
| Author: | Gigafowl [ Mon Jul 13, 2009 2:25 pm ] |
| Author: | stanco [ Mon Jul 13, 2009 9:26 pm ] |
round chimes sound the best. Never seen any square ones. |
| Author: | hyper23 [ Mon Jul 13, 2009 10:27 pm ] |
| Author: | POKER1 [ Mon Jul 13, 2009 10:50 pm ] |
Dats because MB doesn't let you think outside the box. |
| Author: | stanco [ Tue Jul 14, 2009 12:19 pm ] |
| Author: | POKER1 [ Tue Jul 14, 2009 6:46 pm ] |
Not worried Stanky, I got a pedigree to go with it. |
| Author: | coondik [ Wed Jul 15, 2009 12:12 am ] |
is it chimes or... CHINES? btw: skankhoe is dat version 3.0? |
| Author: | willett [ Wed Jul 15, 2009 5:51 pm ] |
CHINES A square chine boat can be turned no problem with stick time...(wider boats are the worst) but anybody should be able to run a square chine boat 40" bottom or less and turn with no problems You aint gonna be runnin fast enough with a 23 LT anyway to have to worry bout sliding but you'll like a sqaure chine for low speed/idling turns better with a longtail anyways not sayin you cant turn a round chine at slow speeds just alot easier to turn a sqaure chine at low speeds and it stay true |
| Author: | robertb4wd [ Sat Jul 18, 2009 7:27 pm ] |
I run a 18x60 Go Devil Surface Drive boat w/ a 35hp Surface Drive. The only difference that is noticable is in deeper water. The round chine will roll up a little more but does not go quite as fast. The square chine boats will get a couple of mph over the round chines. The square chiine also seem to sit a little higher in the water. If it means anything, I've got 29.5 mph on my GPS with just me and my girlfriend in the boat. Go Devil said it should not go that fast, but the GPS doesn't lie. Most of the time it runs in the mid 20's... |
| Author: | deltaduckmaster [ Sat Jul 18, 2009 7:43 pm ] |
Best of both worlds Gator-Tail !! |
