Issues with boat
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=31458
Author:  tsbroscoe [ Sun Aug 12, 2012 8:29 pm ]
Post subject:  Issues with boat
I have a 16x50 flatbottom allweld with 30" float pods with a 35hp godevil that I just got the motor on and I ran it out at the local lake...The boat is completely stripped down...I had a single battery and the gas tank both in the back for now...my self driving and a buddy at the frOnt and the boat was plowing water bad... I know I need to put more weight up front to help but are there any other ideas and what kind of speeds would y'all guess I would be getting???
Author:  Barroll [ Sun Aug 12, 2012 8:33 pm ]
Post subject:  Re: Issues with boat
You are going to want to put your buddy to the back of the boat. Along with battery and tank. It is likely plowing because there is too much weight in the front of the boat.
Now assuming your motor is a surface drive you should probably expect speeds in the mid 20's assuming you have your load balanced properly.
Author:  Woodiebuster [ Sun Aug 12, 2012 8:46 pm ]
Longtail or SD?
Alot of wieght up front will make it plow, but more than likely your problem is those big ass pods making it run too flat and plow.
MM+Pods= No bueno
Author:  tsbroscoe [ Sun Aug 12, 2012 9:06 pm ]
SD
Author:  Woodiebuster [ Sun Aug 12, 2012 9:07 pm ]
Post a picture of the back like the pods and stuff
Author:  tsbroscoe [ Sun Aug 12, 2012 9:28 pm ]
And it's plowing up not down... Boat was not planed out
Author:  270Handiman [ Sun Aug 12, 2012 9:34 pm ]
That's not plowing, that's called not being able to get on plane.
How many rpm's was the motor turning? Has this motor been run on this boat before?
Author:  rob_E [ Mon Aug 13, 2012 10:34 am ]
I have the float pods on a Beavertail boat with a 31 hp surface drive and by myself I can get to 21mph and with someone else in the boat or any load i can only go about 15 I didnt want to beleive it at first but the pods seem to slow you down.
Author:  tsbroscoe [ Mon Aug 13, 2012 12:42 pm ]
Boat is also tunnel hull...does the tunnel hull have to do with the performance... So cut pods off and that would help extremely
Author:  270Handiman [ Mon Aug 13, 2012 12:59 pm ]
Pods and tunnel hull....both elements that will kill the performance of a surface drive motor. That boat sounds like it is set up perfect for an outboard or jet. Best thing to do would be to sell one or the other and get the right set up.
Author:  tsbroscoe [ Mon Aug 13, 2012 1:16 pm ]
Could I weld up the tunnel and cut the pods off and Fix it? By the way sorry for my ignorance on these things it is my first SD... And thanks for the quick replies
Author:  Team Camo [ Mon Aug 13, 2012 1:47 pm ]
Yes, but you're better off selling & replacing it.
Author:  Woodiebuster [ Mon Aug 13, 2012 5:25 pm ]
