It is currently Sat Jan 24, 2026 6:02 am
Reply to topic  [ 19 posts ]
 Can catwalks be added?
Post Can catwalks be added?
So I love my boat but the only thing I would change if I had to do it over again is to have catwalks and spudpoles. I know the spudpoles can be added. How about catwalks? Currently I have 1x1 square aluminum on the outside of the boat on the top of the side. I measured and it looks like a 3 inch catwalk would clear the storage boxes when they are opened. Can a 3x1 piece of aluminum just be welded on the inside of the existing sides, and braced up?
So this would just be a 4 inch catwalk.. What is a standard size for catwalks?
1848 Prodigy
35 GTR
Tue Aug 14, 2012 2:15 pm
Post Re: Can catwalks be added?
Yes it can be done, and mine are 4".
Tue Aug 14, 2012 2:20 pm
1848 Prodigy
35 GTR
Tue Aug 14, 2012 2:21 pm
Brother adds his to the standard gunnels you see on boats.
Tue Aug 14, 2012 2:26 pm
Thanks Owen
Maybe some builders can chime in....What should I be looking at spending for this? (ballpark). Im in georgia and there are no boat builders near me so I am just going to go to a local welding shop and dont want to get screwed. PM me if that easier.
Thanks
1848 Prodigy
35 GTR
Tue Aug 14, 2012 2:50 pm
Bought 350$
Tue Aug 14, 2012 4:45 pm
1848 Prodigy
35 GTR
Tue Aug 14, 2012 5:08 pm
3/16
Tue Aug 14, 2012 5:14 pm
Tue Aug 14, 2012 5:28 pm
a technical question, just for my own education...
How are catwalks built? It seems like it would be very difficult to weld a piece of aluminum to the side rail. How do you hold it in place to weld it?
Why doesn't it just pop off when you step on it-is it just attatched longitudinally to the rail, or does it have some support underneath? Lastly, are they cut to shape from flat stock, or do they have to be bent/fitted into place by cutting slits to allow them to follow the contours?
Thanks.
Spence
Wed Aug 15, 2012 9:53 am
Cut slits into it so you can form it to the sides of the boat, and then weld them back up.
Wed Aug 15, 2012 12:02 pm
Wed Aug 15, 2012 12:57 pm
1848 Prodigy
35 GTR
Wed Aug 15, 2012 1:07 pm
It's not a 3x2.
It's a 3/16ths piece cut 3" wide(or however wide you want it to be) , and long enough for the length of the catwalk.
Then weld on the side piece and make it whatever size you need it to be.
Wed Aug 15, 2012 2:20 pm
1848 Prodigy
35 GTR
Wed Aug 15, 2012 2:22 pm
That depends on how the builder does it. I use 2x3x3/16 angle or 2x4x3/16 however wide you want em and make relief cuts to form it to the side. I see BB takes flat bar and makes the the catwalk and comes back down the side with 1 or 2" flat bar to make the angle down. Ive seen some take flat bar and end it with pipe instead of a angle down its all how your builder does it.
Wed Aug 15, 2012 3:03 pm
I use angle as well it's pretty simple to fit it
Wed Aug 15, 2012 4:05 pm
If you use stock that is wider than the size of catwalk you want, you can scribe a line and cut it without needing to relief cut it to follow the contour of the gunnel.
Fri Aug 17, 2012 8:04 am
Yea but less waste equals more money in your pocket for the builder.
Fri Aug 17, 2012 8:20 am
