It is currently Mon Jul 07, 2025 4:04 am
Reply to topic  [ 35 posts ]
 Hydroturf
Post Hydroturf
Speaking of it, where is the best and cheapest place to get some?
Thu Jan 29, 2009 8:13 pm
Post Re: Hydroturf
Straight from Hydro Turf web site, 30 bucks a sheet on the gray stuff.
Took me 3 sheets for my boat. I think it was 110 bucks with tax and 8 bucks for 2 quarts of the Weldwood contact cement.
Pro Drive m'fers
Thu Jan 29, 2009 8:17 pm
Post Re: Hydroturf
Appreciate it Brooks
Thu Jan 29, 2009 8:19 pm
Post Re: Hydroturf
Thu Jan 29, 2009 8:26 pm
Post Re: Hydroturf
No problem bro.
Keep in mind I didn't put turf on my front deck so if you planning on doing that you'll need 4 sheets
Pro Drive m'fers
Thu Jan 29, 2009 8:45 pm
Post Re: Hydroturf
Ive been thinking of getting some too...hey basin....got any pics?
What about the camo hydroturf that some mudmotor company was selling?
WC 1848 Bateau w/ 36 PD FPR
Fri Jan 30, 2009 7:43 am
Post Re: Hydroturf
Fri Jan 30, 2009 8:17 am
Post Re: Hydroturf
Pro Drive m'fers
Fri Jan 30, 2009 8:19 am
Post Re: Hydroturf
depends on what color you want
Hydrotruf.com only has the basic colors and the b grade
If you want the green that matches the boat call GatorTrax and get 4 sheets There's is the same price as hydroturf.com with the 3M backing already on at $60 a sheet for the green then $80 a sheet for duck swirl camo and nat gear camo
Thats what it used to be anyways
Hydroturf.com of the good sheets shows regular colors $60 sheet plus $25 if you add the 3M backing
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Fri Jan 30, 2009 10:16 am
Post Re: Hydroturf
So, did yall go with the 3m backing or did you add some glue or epoxy to it??
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Fri Jan 30, 2009 11:00 am
Post Re: Hydroturf
I kind of like the cammo from the mud boat company website, would anyone be interested in going in with me and seeing if we can get a discount for a larger order???
Mike Huckabee
Fri Jan 30, 2009 11:02 am
Post Re: Hydroturf
Pro Drive m'fers
Fri Jan 30, 2009 11:03 am
Post Re: Hydroturf
on my PD boat i got it from g-trax with the 3M backing and also sprayed 3M super 90 adhesive and never had problems
New boat went with black from hydroturf.com without the backing and used 3M super 90 spray and almost 4 months no problems
Heard good things bout the weldwood just make sure it gets tacky and make sure where you put the turf down on it is where you want it
Biggest thing i've found and from others advice is MAKE SURE the area is really clean before doing anything
Soap and water dont just do the job either
I wash my boat out really good scrubbing with soap and water let it dry then go back over everything with liquid acetone and regular wrags til there is no black residue on the wrags
Pete Willett
Fri Jan 30, 2009 11:12 am
Post Re: Hydroturf
Fri Jan 30, 2009 2:54 pm
Post Re: Hydroturf
Make sure you clean the floor or area you will be installing the HT. I used denatured alcohol. Went with the adhesive backing, and 3M Super 90 spray. Be liberal with Super 90 and cover the area real well with it. Let is setup about 5 minutes and then stick on the HT.
Crisis defines character
Fri Jan 30, 2009 8:48 pm
Post Re: Hydroturf
Pro Drive m'fers
Sun Feb 01, 2009 4:49 pm
Post Re: Hydroturf
I got the B grade stuff and only found one little defect out of 5 sheets.
1854 Gatortail CC . 35 GTR Stage 2
Sun Feb 01, 2009 7:47 pm
Post Re: Hydroturf
Can and will you take a pick of it for us? The stuff you got is the diamond surface right? Instead of the grooves.? How slip resistant is the diamond vrs the grooved surface? $30 bucks/sheet is a deal if it works as well. Color matters not to me, after opening day everything gets a nice coating of marsh mud, and I think it goes against the nature of a true duck hunter to put a hose pipe to it. When God gets tired of looking at my dirty boat, he sends rain.
...Dead Bird...B-A-C-K!
Fri Feb 06, 2009 7:40 am
Post Re: Hydroturf
In my experience there is little to no difference in grip associated with the pattern shape. The pattern is more for looks. HT, due to its foam nature provides a great surface for traction despite the pattern.
I went with the "B" grade in charcoal color and put it down by myself with the 3m 90 spray. The only problem I had was needing some extra hands to help me. It has held up well and still looks good after lots of mud, sticks, and duck blood. I cover my boat when not in use so it should last a long time. I will use it again when the day comes. I can't see spending the extra on camo though. After a hunting season mine has its own nature made camo color.
Fri Feb 06, 2009 10:45 am
Post Re: Hydroturf
Cool. I was just thinking the grooved stuff might channel water away a little better.. but if it's just looks, who cares. I'm kinda partial to the diamond tread pattern anyway.
Fri Feb 06, 2009 12:31 pm
Post Re: Hydroturf
Having hydroturf makes it easier to persuade the women to sunbathe in your duck boat. ;)
Fri Feb 06, 2009 1:28 pm
Post Re: Hydroturf
Fri Feb 06, 2009 7:18 pm
Post Re: Hydroturf
I got the duck swirl or whatever the hell Gator Trax calls it with the 3M backing. Easy to install and I reccommend getting some 3M Super 90 spray to go with it.
Tue Feb 10, 2009 7:30 pm
Post Re: Hydroturf
Tue Feb 10, 2009 7:34 pm
Post Re: Hydroturf
WC Custom 1854
Tue Feb 10, 2009 7:50 pm
Post Re: Hydroturf
Tue Feb 10, 2009 9:01 pm
Post Re: Hydroturf
Sometimes its OK to admit you don't have a girlfriend, sometimes. :lol:
18x48 Charles Leonard / 36PD
Tue Feb 10, 2009 9:03 pm
Post Re: Hydroturf
"Fight 'em until hell freezes over. Then fight 'em on the ice!"
Wed Feb 11, 2009 9:52 am
Post Re: Hydroturf
LOL.... Ok you got me there, shes made up. She does not exist.
Wed Feb 11, 2009 10:07 pm
Post Re: Hydroturf
I too got the b grade gray diamond. Found no defects in 10 sheets. (two boats got covered and boxes) We used the contact cement on first and 3m 90 on 2nd (mine). I do not recommend 3m 90. Did not hold. Had to go back with the contact cement. the only problems we had with the contact cement is if you put to much on it will cause air pockets. You also need to have plenty of weight on top of it for 24 hours to dry. Otherwise holding great if done that way. I recommend bags of sand if you have obstacles/seat bases to overcome. If I were to do it again, I would buy the 3m backing on it and be done.
BLAH, BLAH, BLAH.......SHUT THE HELL UP!
Sun Feb 15, 2009 7:18 am
Post Re: Hydroturf
I just realized sand man's and shaggychat's avatar is da same girl!
Sun Feb 15, 2009 1:57 pm
Post Re: Hydroturf
Sun Feb 15, 2009 8:15 pm
Post Re: Hydroturf
That's some of the best mammary glands I've seen in a little box on a screen next to somebody's comments,and I like them ALOT!
Sun Feb 15, 2009 8:34 pm
Post Re: Hydroturf
She shore likes to shake em. :mrgreen:
Sun Feb 15, 2009 8:39 pm
Post Re: Hydroturf
Ha, ha. He said "bags of sand."
Kinda funny, given his avatar.
18x48 Brother Breaux 36 PD FPR
Fri Mar 06, 2009 3:20 pm
Users browsing this forum: Google [Bot] and 99 guests
