It is currently Mon Dec 15, 2025 9:15 pm
[ 2 posts ] |
kontekontos
 Foam in boat
Besides taking the foam out for good is there anything you can use to seal up the foam that is in the bottom of the boat so that it doesn't absorb as much water. The tops and bottom of the foam are sealed,but it is on the sides that don't seem to be sealed and that allow the foam to really absorb water. Any thoughts on this.
konte
| Thu Jul 23, 2009 8:56 am |
Mudgun
Joined: Wed Jan 14, 2009 12:24 pm Posts: 746 Location: Here Be Rocks VA
 Re: Foam in boat
Hey, you've got a SDB hull right? Did they bend the side panels over the floor panels in your hull? When I went to pull the floor panels up to replace the foam I damn near had to tear the boat apart to get the floor panels up. As for sealing the white foam under there......nope. You're gonna have to get it out and put Dow Duramate or somthing like that down.
_________________ 1660 Rhino High-Side with center console 90/65 Mercury 2 stroke Outboard jet pump Run shallow, run loud.
| Thu Jul 23, 2009 11:47 am |
[ 2 posts ] |
