It is currently Sat Jul 12, 2025 12:52 pm
Reply to topic  [ 10 posts ]
 Pods on a 1448?
Post Pods on a 1448?
I'm new to the mud boat world and I have a 1448 that has weld on pods on it I was curious if I could add any flotation to them and if so what would ya'll use or have used in them.
Mon Nov 05, 2012 8:12 pm
Post Re: Pods on a 1448?
I would cut them off of the boat iffin I was gonna mount a sd on it.
HOTSAUCE170 wrote:
Mon Nov 05, 2012 8:14 pm
It has a 23 mud buddy on it, the guy I got it from had them cut and shaped so you can turn the motor completely.
Mon Nov 05, 2012 8:22 pm
You want to be able to drain them and if you fill them with some floatation foam, you won't be able to. The pods should be totally water tight, so there isn't much point in adding floatation in the pods. I'd keep those pods on that 1448 because the weight of that motor sinks the transom down quite a bit without the pods. I no longer have my 1448, but pods were a good addition when I had a 25 longtail on it.
Wed Nov 07, 2012 9:46 pm
Why do you want flotation in them?
Wed Nov 07, 2012 10:03 pm
Thu Nov 08, 2012 9:22 am
My opinion is that they are idiots.
Thu Nov 08, 2012 11:47 am
Pods are a joke
Thu Nov 08, 2012 6:20 pm
Pods rob the motor of water by creating alot of turbulance. By a motor that is best suited for your boat with out having to add stuff to the boat.
If you fill them with foam and it leaks then you got the same problem go-devil has, water logged foam will put more weight on that rear end than you can imagine
Thu Nov 08, 2012 6:23 pm
Plan A
leave them on. The flotation = L x ((W1+W2)/2)x h x62.4 = # of floatation
Convert everything to feet. The pods add significant uplift behind the transom and Counter act the massive moment arm called a mud motor.
Plan B
Buy a mud boat. That's my next step. Jon boat mods suck. Still a jon boat.
Good luck.
Wed Nov 21, 2012 6:35 pm
Users browsing this forum: Google [Bot] and 121 guests
