Short transom gatortail http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=34620 |
Author: | sela_native [ Sat Nov 24, 2012 8:30 pm ] |
Post subject: | Short transom gatortail |
Could someone post a picture of a gatortail trimmed all the way down, so i can compare |
Author: | UNCLE-J [ Sat Nov 24, 2012 8:50 pm ] |
Post subject: | Re: Short transom gatortail |
What ya need to know. If your not trimming deep enough, make sure you are on bottom pin |
Author: | sela_native [ Sat Nov 24, 2012 9:07 pm ] |
You got it, its on bottom pin, belt housing is about two inches from bottom but i can do shit in shallow water. Big blade prop 12" measured. I feel like im not getting to dig down deep enough bc i spray muddy water everywhere! |
Author: | UNCLE-J [ Sun Nov 25, 2012 5:45 am ] |
You post a photo of your motor. A couple different angles |
Author: | DuckHunterF250 [ Sun Nov 25, 2012 8:05 am ] |
Whats your transom angle? |
Author: | marsh mule [ Sun Nov 25, 2012 8:30 am ] |
I'm at work but can when I get home. But short/tall transom should be the same at the bottom of the boat. |
Author: | UNCLE-J [ Sun Nov 25, 2012 9:41 am ] |
Beings his signature says Ribbed Boat, I can pretty much guarantee that it is a 16 degree transom. Not enough angle. You need to shim outside top out about 1/4" or so. Then ya problem will be resolved. |
Author: | Skipr [ Sun Nov 25, 2012 11:15 am ] |
When I had my ribbed boat I ran my GTR with the pin in the bottom hole. I was able to trim up to just the right height for the prop to be 1/2 out and down enough to dig out in the shallows. I hope this helps. |
Author: | UNCLE-J [ Sun Nov 25, 2012 12:20 pm ] |
It doesn't help |
Author: | dog walker [ Sun Nov 25, 2012 12:51 pm ] |
Author: | craig [ Sun Nov 25, 2012 12:55 pm ] |
Author: | marsh mule [ Sun Nov 25, 2012 1:16 pm ] |
^^ that just a 1x4? |
Author: | craig [ Sun Nov 25, 2012 1:45 pm ] |
1/4" x 2" |
Author: | sela_native [ Sun Nov 25, 2012 7:30 pm ] |
Its an 1650 xpress. When i bought it, it already had shims but they are in the inside ...... gonna change that and see. Also it stays on the bottom hole. Thanks for the replies! |
