| 1654 vs 1748, 1744 http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=34763 |
| Author: | nautibynature [ Wed Nov 28, 2012 11:42 am ] |
| Post subject: | 1654 vs 1748, 1744 |
I have a 27 pd and will be having a boat built for it. I usually hunt 2 people, dog, dozen decoys. Occasionally I would like to hunt three and be able to get on plane. I currently run a 1648 Lowe, 15 to 17 mph with usual load... Add a third person and it plows at 7mph. I want a boat that I can live with while I have the 27, and I will be dam happy with when I put a 36 on it. I was thinking the wider boat would be more stable and draft less, but I'm not sure how performance would compare to longer and skinny. |
| Author: | deltaduckmaster [ Wed Nov 28, 2012 11:49 am ] |
| Post subject: | Re: 1654 vs 1748, 1744 |
17x44 or 48 |
| Author: | willett [ Wed Nov 28, 2012 11:58 am ] |
Either will work well with either HP motor. 48 will handle the larger HP a little better as far as stability but really not too much difference |
| Author: | nautibynature [ Wed Nov 28, 2012 6:28 pm ] |
I was thinking in terms of wakeboard vs slalom ski. The shorter wider wakeboard pops up with less effort and speed. Go too fast and it gets unstable and hard too ride. A slalom ski takes much more effort too get up on, but once up speed and agility don't even compare to the wakeboard. Probably not the best comparison since we are only talking about 6 to 10 inch difference in the width. I was hoping somebody on here has strapped a 27 on one of these sizes. Just being on a smooth bottom should be a huge improvement on what I'm running now. |
| Author: | dozrya [ Wed Nov 28, 2012 6:45 pm ] |
TCK had a 27 Go Devil on an 1854 Uncle J and it was not terrible. 1748 would do the trick though. |
| Author: | willett [ Wed Nov 28, 2012 7:56 pm ] |
You will see a huge difference just by having a boat built that suits the motor. That Lowe boat is nowhere close to what you need. If you are going to be hauling 3 people you can not ask much from the 27 PD. For the 27 to haul that heavy of a load = longer is better. 18-20' 44-48 wide is going to be the best. Square chine would be best for this also but takes learning how to make it turn and not slide. The Wider you go the harder any of them are to turn since they are slick and flat. Also depends on your weight, and the other people's weight and what other "permanent weight" is going to be in the boat. We built an all 1/8" 1744 double tapered chine for a guy running a brand new 27hp PD (hp restriction where he runs). He wanted ALL SORTS OF STUFF in the boat and he weighs atleast 250 alone. With him and battery in rear, driver box, gun box, and then trolling motor, TM battery and gas tank in front - he only gets 22-23 mph Take that crap out except rear battery, gas tank and with me driving (180lbs) I can hit 25 mph. I believe if we had built it square chine it would be doing a little better but again you're not going to see much out of the 27 with a lot of weight. |
| Author: | nautibynature [ Wed Nov 28, 2012 8:24 pm ] |
I weigh 210, dude I hunt with 190, 80 lb dog, dozen decoys, and scissor blind with fast grass + tarp for wind blocker. I don't hunt 3 all the time but would like to from time to time. I want an open floor with no boxes, seats, or extended front decks. This boat will only be used for hunting related purposes. Thanks for the replies! |
| Author: | willett [ Wed Nov 28, 2012 8:42 pm ] |
Extended front deck is all about what you want. You can make it however long you want and still have an extended portion to keep stuff out of the way from being stepped on and such. Open floor plan except maybe a driver box is going to help save a lot of weight. 4' deck total 2.5 foot for storage and 16" extended. Gas Tank up front for sure. Again 1844-48 wide will be fine. Back when I first started the surface drive game in 2006 I had a 27PD on a 1748 PD Boat with a similar load like you described I was running 22-23mph and 25-26 by myself. Add the third person and it would drop to about 18-19. If it had been about a foot longer then it wouldn't have dropped off quite as much. May not have seen much better empty speeds but load carrying wouldn't have dropped off as bad. Then when I moved up to a 36 and it was perfect for what I wanted at that point in time. |
| Author: | QuackStacker5253 [ Wed Nov 28, 2012 11:52 pm ] |
My 27 on the 1748 willett built me will touch 26 when empty. I loaded it with 2 other guys and gear the other weekend and it got on plane fine but would only run right around 20. I wouldn't expect the world from a 27 they just don't haul a load well. If your stuck with a 27 right now I would build a boat that will work for now and be just right for a bigger motor down the road, that's what I did. 1748 or 1848 is the best size all around IMO. |
| Author: | nautibynature [ Thu Nov 29, 2012 5:17 am ] |
Exactly the kind of info I was looking for... Thanks guys. Quackstacker you have any pics of your rig? |
| Author: | tylerduckman [ Thu Nov 29, 2012 5:59 am ] |
I'm jumping on plane with 3 guys , dog and hunt load with a 27. It will hit 17 - 18 pretty quick with that load. Long and skinny!!! |
| Author: | willett [ Thu Nov 29, 2012 7:25 am ] |
| Author: | nautibynature [ Fri Nov 30, 2012 8:52 am ] |
Willet, sent you a pm and an email |
| Author: | OwenDickeson [ Fri Nov 30, 2012 9:35 am ] |
I would go 1844. Square chine. With a little bit of a load in the boat, you can make that narrow square chine carve. Or go triple taper. |
| Author: | DuckPlucker19 [ Sun Dec 02, 2012 1:07 am ] |
I have a 17x48 with a 27hp. Saving for a 36hp now let me know if your still looking to buy a motor in January let me know, the day after hunting season it will be for sale. |
| Author: | nautibynature [ Sun Dec 02, 2012 5:52 am ] |
Duckplucker, I already have the motor. What make is your hull? |
