It is currently Thu Nov 19, 2026 2:25 am
Reply to topic  [ 6 posts ]
 1436 with 9 hp Go Devil LT set-up questions...
Post 1436 with 9 hp Go Devil LT set-up questions...
Hey guys, new to the forum and looking for advice.
Here is the situation. Looking to possibly buying a boat from a friend. It is a 1436 Sea Nymph with a 9 hp B&S GoDevil LT. Not sure on the year. I've been running the boat for the past couple weeks deciding if I like it or not. For what i'll use it for, I think i'll do the job but it is SLOW with my normal load.
I know that combo won't break any speed records, but i'm fairly confident that there is more left in that little motor.
A little background:
I believe the motor has the original prop, a 3 blade 8x4. I'm guessing a new prop will go a long way on this set-up. Yesterday we were running 7 mph with 2 big guys (235 and 205) and all our gear (blind bags, guns, decoys, etc...).
What are realistic performance numbers on this rig? Could we eek out a few more mph? What are you guys running on similar set-ups? What props?
He has a 13 hp Honda powerhead that we're thinking about swapping to. What gains would we see and what prop should we running on that set-up?
Thanks for the info guys!!
Jose
Thu Nov 29, 2012 2:46 pm
Post Re: 1436 with 9 hp Go Devil LT set-up questions...
thats prolly about all your going to get out of that LT, i have a modded 27 and all i'm getting is 22 in the shallows, if he will trade the powerhead for the 13 honda(and its in good running condition) do it cant argue with 4 extra HP. other then that a new prop will do you some good. try playin around with placement of the load in the boat(i know its hard to do in a boat that small) and just make sure the boat isn't plowing water. hope this helps
,Trey
Thu Nov 29, 2012 6:25 pm
Think a 2 blade prop would be better
Thu Nov 29, 2012 6:33 pm
Yeah, the boat seems to plow water with 2 guys but at the same time feels faster than when im by myself.
Do these longtails run better with a load in the back or front?
Still working on getting a new prop and or wrenching on the motor. My buddy says the 13 Honda is actually smaller than the 9 but not sure of any weight savings.
Sent from my SGH-T989 using Tapatalk 2
Wed Dec 05, 2012 7:38 am
I balance my load and Im not setting speed records. I get there safe and reliable.
Wed Dec 05, 2012 8:34 am
That performance is pretty much what I would expect...I ran a 9hp LT on my Gheenoe Classic for a little while (longer and wider than your jonboat) and maxed out around 12-13mph by myself, and I'm only a buck-fifty.
15'6 Gheenoe Classic / Copperhead SD
Wed Dec 05, 2012 2:02 pm
