| Livewells and Aereators?? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=34956 |
| Author: | willett [ Mon Dec 03, 2012 4:40 pm ] |
| Post subject: | Livewells and Aereators?? |
I do not fish much so I have never had to hook up or use a livewell with an aereator system. A boat we are building is wanting a livewell setup with aereator. For the most part I understand the concept You have to let water in and then need an overflow drain. But how do you keep from overfilling? then there are timers, how exactly do you hook these in to circulate the water? Just like you would a regular switch? What is a good pump and timer and other parts? |
| Author: | riverratdm84 [ Mon Dec 03, 2012 5:10 pm ] |
| Post subject: | Re: Livewells and Aereators?? |
On my old boat I had a timer with swich all you had to do was run a hot to it then run a wire to your pump. My pump just screwed into a hole I drilled in the back. Just run an overflow out the side of the boat and into your livewell at the height you want your waterto be. |
| Author: | WestEndAngler [ Mon Dec 03, 2012 5:37 pm ] |
You have an overflow like riverrat mentioned. Also, to really keep fish & bait alive an oxygen system is a must have. The bait / fish come out of there on crack |
| Author: | T-Bubba [ Mon Dec 03, 2012 6:51 pm ] |
if he is bass fishing i'd recommend a recirculate also... |
| Author: | Old School [ Mon Dec 03, 2012 6:54 pm ] |
I use a portable Keep Alive, it keeps shrimp alive for 2 days with same water. |
| Author: | 270Handiman [ Mon Dec 03, 2012 7:25 pm ] |
This is a good website for livewell ideas and diagrams. They also make great products. http://www.shurflo.com/marine-products/ ... fault.html |
| Author: | txmudcutter [ Mon Dec 03, 2012 7:28 pm ] |
| Author: | gfowel [ Mon Dec 03, 2012 7:35 pm ] |
Shurflo Piranha pumps are great. That's what I would use. There are a thousand different ways to set up a livewell. I would ask your customer what he wants and go from there. |
| Author: | Old School [ Mon Dec 03, 2012 7:39 pm ] |
