It is currently Thu Nov 19, 2026 2:03 am
Reply to topic  [ 18 posts ]
 Gator Tail stern light
Post Gator Tail stern light
I don't really care for the stern light on my gator tail, it's just the standard 36" perko light that plugs into the socket on the transom. Looking for some ideas on mounting a light or a small led strip on back of motor. Something that has a lower profile and less vulnerable to being broken off. Any ideas or pics would help.
Thu Nov 29, 2012 1:27 pm
Post Re: Gator Tail stern light
What ever you do don't drill a hole in your breather. Lol
17x48 extreme stage 2 GTR
Thu Nov 29, 2012 1:30 pm
No I'm not, imma drill into the exhaust... Lol
Thu Nov 29, 2012 1:46 pm
Leave your pole light. Cut the metal all the way through and slip peice of rubber hose over it with hose clamps on both ends. It will bend as you hit stuff with it.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Nov 29, 2012 1:53 pm
Back Yard Bullshit 1848 with Delta stage II cam & heads, MAC, with a Mikuni juice pump.
No I wasn't talking about you but if the shoe fits lace that bitch up & wear it!!!!
Thu Nov 29, 2012 2:05 pm
Atwood wake tower LED mounted on top of breather cover
Thu Nov 29, 2012 2:34 pm
Bayou Surface Drive
337-351-0362
Thu Nov 29, 2012 2:54 pm
Not exactly true.
Thu Nov 29, 2012 3:00 pm
Supposed to be mounted at least 39" higher than the red and green lights I think.
Thu Nov 29, 2012 3:02 pm
Honestly...game warden is not going to pull out a tape measure. Mine can be seen in 360 degrees even with boat approaching head on. It sticks up higher than everything in boat and is bright.
Thu Nov 29, 2012 3:13 pm
Just being technical.. if you stand up while driving your stern light will be blocked by your body... LOL I know its stuppid, But you get my point. I run with a standard 18" ISH? attwood light from academy.
Bayou Surface Drive
337-351-0362
Thu Nov 29, 2012 3:21 pm
Thu Nov 29, 2012 3:23 pm
True. If you have a light on when you are supposed to and it can be seen Mr. Green jeans is not going to bother you. I have found this is the most effective way at moving your light free of getting snagged on things and still trying to obey the law.
Thu Nov 29, 2012 3:29 pm
Barnes, where you get that???
Sat Dec 01, 2012 12:51 am
im no expert but i thought the anchor light was 360 deg.,or all round.
red and green shine straight ahead and 120 deg or so behind the beam.
stern light shines 67.5 degrees on each side the stern...total arc of 135 deg.
i do realize that the perko stern lights are all round....im going by coastguard regs.
also i think an all round white light is required when no running lights are avail.
on a vessel less than a certain length,making less than a certain speed.
its been a long time...........
if im wrong,it definately aint the first time lol.
Sat Dec 01, 2012 1:28 am
An who cares about technicalities......buy the light, install and fucking roll.
Google Atwood led tower light
Sat Dec 01, 2012 1:34 am
[quote="barnes_53"]An who cares about technicalities......buy the light, install and fucking roll.
X2
Tue Dec 04, 2012 8:40 pm
Tue Dec 04, 2012 10:34 pm
