pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
Alweld Mud Boat??
Fri Dec 28, 2012 9:05 pm |
keystone light
Joined: Mon Dec 27, 2010 4:04 pm Posts: 320 Location: Setx
Re: Alweld Mud Boat??
Are they .125 aluminum?
_________________ 17x50hd gator trax 45mag mb
Fri Dec 28, 2012 9:11 pm |
pokey79
i heard nothey are .100
Fri Dec 28, 2012 9:17 pm |
keystone light
Would be a good marsh boat at the least.
Fri Dec 28, 2012 9:23 pm |
scatters boy 316
Joined: Sun Jun 05, 2011 9:19 pm Posts: 721 Location: carrollton MS
How much does it cost? And what sizes does it come in?
_________________ 8 foot sneak boat with 8hp go devil going Mach 1 Layout blinds and a whole bunch of decoys
Fri Dec 28, 2012 9:56 pm |
50fps
Sat Dec 29, 2012 1:43 pm |
scatters boy 316
5500 dang, you could get a custom hull built for that.
Sat Dec 29, 2012 1:52 pm |
eljefe
Joined: Thu Jan 13, 2011 7:32 am Posts: 5210 Location: Beaumont Texas
the hybrid looks nice....
_________________ You can't see the sunrise if your eyes are closed. dying aint much of a livin....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com fuel injected 25 GTR
Sat Dec 29, 2012 2:31 pm |
Docott
Gator Tail Boat, 1854: $4,900. Just sayin' as an example of what's available in that price range. I imagine the other companies that specialize in mud boats will have similar offerings. Custom builders too. http://gator-tail.com/boats.html
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
Sun Dec 30, 2012 12:28 am |
Puddler45
Joined: Thu May 03, 2012 9:07 am Posts: 1199 Location: Wisconsin's waters and woods
I'm considering buying one of these in spring after the ice season is over. This boat seems to be halfway decent. I was told 4500 for a 1748 + 250 shipping for a flat front with navigation lights. Id probably go 1744 I'm looking to stay light weight running a 23 and it wouldn't see a lot of harsh conditions mostly marshes a few rivers and fishing in deeper water clean bottom lakes.
the alweld is .100 where most are .125 It has 4 - 1.5" x 4" longitudinal bracing 5 in 50" wide (gator and prodrive uses 1" x 2" 5- 48) Full welded in floor and side skins (for added hull strength) gunnel rail w/ rigging chase full upright and level floatation split rear seating smooth bottom except for one rib down the center hunt deck option
Price -1748 4750 w/ shipping and nav lights gator tail - 1746- 4100 (shipping?) go devil - 1648 - 4050 w/o shipping 1848- 4400 w/o shipping (tall transom +$100) pro drive - 1748 - 4920 (shipping?)
So the questions is does the larger bracing in the alweld with welded floor and side skins which makes for a narrower width in between bracing make up for the .100 gauge hull. Would it be close to the strength of a .125 designed like a go devil or other manufacture. The price seems a little high considering its .100 but is still priced in the middle of the production hulls. Ill get a closer look in spring when I look at em and make my final descion.
_________________ 1744 floating a 23 MBHD Stage 2
Wed Jan 02, 2013 1:28 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
An alweld will never compare to a true mud hull no matter how u look at it also if u can get a true mud hull built by a mudmotor manufacturer for a couple hundred more why would u question it? U pay for what u get
Wed Jan 02, 2013 1:58 am |
instagator911
Joined: Sat Dec 05, 2009 12:36 pm Posts: 1127 Location: Behind the hood next 2 da bright light! SETX
2 words.
Horizontal ribs!
2 more.
Wash board!
_________________ Jay Dore
Wed Jan 02, 2013 3:04 am |
Puddler45
this is a logitudinal braced mud hull what I was told is the guys at sw marine designed it and alweld builds it
Wed Jan 02, 2013 3:21 am |
Beaver Puddle
Joined: Mon Mar 09, 2009 10:29 am Posts: 24 Location: Cedar Rapids, IA
I don't normally post, but I thought I would clear up some of the questions regarding the Alweld mud boat.
As many of you already know, we carry several mud boat lines including Gator Tail, Excel and also the Alweld mud boat. All are great boats and each has there strong points.
The Alweld mud boat right now comes in sizes ranging from 1544 through 2052. Flat or V bow.
Standard Features: smooth bottom with one center keel. longitudinal bracing 100% welded construction complete floor and side skins that is 100% welded in. closed cell foam injection in floor and sides. The entire boat is 0.100 gauge. (with the bracing used and the floor and sides continuously welded, and with the foam there is no need for 0.125 with this design). two knee braces supporting the all aluminum transom. tread plate, reinforced bow cap and corners. nav lights. heavy gunnel rail. non-skid interior. split rear seating. Rigging chases on both sides from stern to bow. Coast Guard approved rating. 38" bow deck.
We also offer the bow with a open under deck extension, locking bow deck storage or bow drop deck design. There are host of other options, including a rear drop deck.
We are working on some larger versions of this boat to accomidate dual motors.
Pricing completely depends on how the boat is set up and what features are added. But, for example. A 1852 Mud, with the standard features listed above, is about $5,500 with freight (of course freight charges can vary)
When the boat is purchased as part of a package, discounts may apply.
Wed Jan 02, 2013 3:31 pm |
Beaver Puddle
Oh forgot. Of course, the Alweld mud boat has a tapered chine.
Wed Jan 02, 2013 3:34 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
There may be a market for those hulls up north, but at that price I can't see many people from down here buying them when you can get a 1/8" - 3/16" thk. PD, GT, or custom built hull for less. And you may want to re-think the logic that the continuous welding of the sides and foam in the floor will magically keep a .100" bottom from denting. Although if I were a salesman I may try to use that pitch as well...just my .02
_________________ 35 GTR - 1754 Extreme
Wed Jan 02, 2013 3:50 pm |
CJB
Boat looks good though...
Wed Jan 02, 2013 3:51 pm |
instagator911
Wed Jan 02, 2013 7:27 pm |
