netman
Joined: Wed Jan 14, 2009 3:48 pm Posts: 2363 Location: Chandler,Indiana
 welding question
Whats your thoughts on butt welding two sheets of 5'x12' together to make a bottom for a skiff? Bottom thickness is .190 aka 3/16 5052. I have checked with my local steel/alum supplier and he said twelve foot was the longest sheet he could get. I would have to have the twenty foot sheets shipped in which I would prefer however I would like to build me a skiff sometime in the next couple months. The five by twelve sheets of .190 cost $400 per piece.
_________________ I got a shotgun,rifle and a Go Devil Surface Drive a country boy can survive. 35+hp GDSD engine mods by George Merta 18x48 GDSD boat
| Tue May 07, 2013 6:38 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: welding question
try to find a diffrent aluminum supplier cause we get 20 foot sheets down here in louisiana all the time cause it cost more to get a cut sheet!!!
| Tue May 07, 2013 7:04 pm |
OlSchool
Joined: Sun Jan 06, 2013 4:24 pm Posts: 384 Location: Louisiana
Aluminum & Stainless or Pierce Aluminum
Both have places in New Orleans and Broussard
| Tue May 07, 2013 7:27 pm |
eljefe
Joined: Thu Jan 13, 2011 7:32 am Posts: 5210 Location: Beaumont Texas
he is in indiana, not la
_________________ You can't see the sunrise if your eyes are closed. dying aint much of a livin....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com fuel injected 25 GTR
| Tue May 07, 2013 7:28 pm |
Capt. JJ
It's not ideal, being it's going to take more time and attention to keep everything fair, but any aluminum boat over twenty feet is going to have a seam weld, so it's no big deal if done right. We use to seem those 5x12 sheets together all the time on 12' decked over air boat hulls and never had that center seem fail. I've welded on many 100'+ aluminum crew boats and there made of many sheets welded together
| Tue May 07, 2013 7:57 pm |
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
Mandel metals in Chicago carries a wide range of material and will have 20 footers
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
| Tue May 07, 2013 8:11 pm |
netman
Thanks a bunch guys. I really appreciate your input.
| Tue May 07, 2013 8:15 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
X2 I don't see a problem with it at all especially on 3/16. Get good penetration and you will be fine
| Tue May 07, 2013 9:06 pm |
Bigbuckfever
Joined: Sat May 28, 2011 11:18 pm Posts: 2114 Location: Slinger, WI
Out of curiosity, would you chamfer the ends of the sheet before welding to help with penetration? Or just weld flat end to flat end?
_________________ Every day I'm paddlin' 1848 Gatortail boat and 37 efi GTR.
| Tue May 07, 2013 9:17 pm |
dfou
For what he's doing I would bevel the edges and leave a small gap between the sheets
| Tue May 07, 2013 9:22 pm |
forever draggin
Joined: Tue Jan 13, 2009 7:10 pm Posts: 6664 Location: in the marsh with a boat load full of dead hookers
X2. Just be careful when buffing the weld not to dip into the sheet.
| Tue May 07, 2013 9:27 pm |
banded-mallard
| Wed May 08, 2013 5:07 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
It's gonna b hard to keep the weld seam from getting distorted, or dog legging.
_________________ 18'x54"CC Hanko/ 36PD
| Wed May 08, 2013 2:14 pm |
Bigbuckfever
| Wed May 08, 2013 2:20 pm |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
On .188" material I wouldn't bother with beveling the edges. I would leave a .188 gap and use a .188 backer plate. The backer plate will help with some of the distortion.
Mag 10
| Thu May 09, 2013 11:07 am |
netman
Im having to pay 2.50 per pound here locally. I called Mandel in Chicago and it was 1.87 per pound. They had one twenty foot 3/16 in stock however no idea of when they will have more. I am going to call Tals buddy at Pearce and see what I can come up with. Thanks for the replys.
| Thu May 09, 2013 11:11 am |
Kmoppert
Joined: Tue Jun 05, 2012 3:48 pm Posts: 2006 Location: Baton Rouge, LA
_________________ "There's nothing a duck hunter hates more than another duck hunter" ----------------------------------------------------------------------------------------------------------------------------------------------- Custom 17x48 with a new Gen III Prodrive.
| Thu May 09, 2013 12:16 pm |
Bigbuckfever
| Thu May 09, 2013 12:42 pm |
netman
K Im not sure. Tal said he could hook me up.
| Thu May 09, 2013 3:12 pm |
Mag10
"Would the backer plate be used structurally? Or just to avoid weld splatter?"
It is somewhat structural. It is used to focus the depostion between the components that you are trying to join. The weld nugget will tie the 2 sheets and the backer stip together instead of letting the energy just blow through the gap and thus bettering the posibility of a complete joint penetraion. Because you are adding a strip of material you are creating a "backbone" along that joint that can help with distortion along the length of the weld.
Mag10
| Fri May 10, 2013 11:52 am |
