If you could do it over, what would you change on your boat?
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=40815
Page 1 of 2
Author:  muddog85 [ Thu May 16, 2013 4:30 pm ]
Post subject:  If you could do it over, what would you change on your boat?
First post. Hello.
Going to order a GT Extreme in the near future (hopefully). Instead of asking what you all love about your boat......if you could change a few things on your boat what would do?
Likewise, if there was an option you didn't get that you should have or just something you really want let me know.
Don't want to order the boat and feel like I've missed something after dropping lots of money.
Author:  tchauvin [ Thu May 16, 2013 4:35 pm ]
Post subject:  Re: If you could do it over, what would you change on your b
I woulda went bigger, instead of 17, i would have went 18'
Author:  Quackhead62 [ Thu May 16, 2013 4:47 pm ]
I would go with a custom haul like a Uncle J or one along those lines so I could have more input on what I want in the boat an what I don't want.
Author:  med [ Thu May 16, 2013 4:54 pm ]
Would have started with a pd instead of lt and went with a custom boat so i could have a 3/16 bottom.
Author:  CCC [ Thu May 16, 2013 5:11 pm ]
Cat walks, big ones! Winch in the front, hunt deck, welded floor, and longer like 18 or 19 foot
Author:  Kmoppert [ Thu May 16, 2013 5:13 pm ]
I'd like 3 more inches.
Author:  bayouboy [ Thu May 16, 2013 5:19 pm ]
18 footer
Author:  oncall [ Thu May 16, 2013 5:20 pm ]
Only one 2" drain and one standard drain, I currently have two 2" drains.
Author:  msm8281 [ Thu May 16, 2013 5:26 pm ]
Author:  deltaduckmaster [ Thu May 16, 2013 5:32 pm ]
Author:  JIMMY W [ Thu May 16, 2013 5:52 pm ]
I would not change a damn thing ;)
Author:  Will [ Thu May 16, 2013 6:10 pm ]
if I had room in the garage, a 2060 with duals...
Author:  deltaduckmaster [ Thu May 16, 2013 6:12 pm ]
Author:  Orangefoot362 [ Thu May 16, 2013 6:28 pm ]
Dual 2 inch drains but that would be it
Author:  dirtybird29+ [ Thu May 16, 2013 7:00 pm ]
Cat walk, front mounted winch
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Author:  mcduffws [ Thu May 16, 2013 7:09 pm ]
Beer holder in the catwalks
Author:  CJB [ Thu May 16, 2013 7:11 pm ]
Author:  bubba777 [ Thu May 16, 2013 7:12 pm ]
Put heavy machine guns in front of boat !!!!!!!!!
Author:  forever draggin [ Thu May 16, 2013 7:14 pm ]
Author:  BayouBuster [ Thu May 16, 2013 7:28 pm ]
6" catwalks, 1 foot longer, 2" drain plugs, and maybe 48" bottom instead of 54".
Author:  BayouStateHunter [ Thu May 16, 2013 7:30 pm ]
Higher sides, spud poles. Wish I had the new style floor. 2009 boat
Author:  oncall [ Thu May 16, 2013 8:01 pm ]
Author:  SCStrokin [ Thu May 16, 2013 8:22 pm ]
2" drain plugs, A beer holder in my catwalks, clearcoat on my perty paint.
Author:  quackconsumer [ Thu May 16, 2013 8:32 pm ]
Only thing I would have done different is put dual modded GTR's instead of one. And dual consoles.
Author:  ha2 [ Thu May 16, 2013 8:51 pm ]
went with 2 drain plugs, put in a half box instead of a welded in drivers pod, pipe chases to front of boat, and a hunt deck. and a front and rear winch recievers
Author:  Kmoppert [ Thu May 16, 2013 9:03 pm ]
Author:  deltaduckmaster [ Thu May 16, 2013 9:13 pm ]
Author:  2ducks [ Fri May 17, 2013 12:33 am ]
A thought for keeping decoys out of the way, a lot of os use texas rigged dekes. This year I'm thinking about taking 4 3/16 diameter rods and bending a loop in one end. A couple of hole in the catwalk then slip these poles in with the loop up angled just over the edge of the boat. The clip you carabiners to the "eye" and your dukes should dangle right at th tunnel. One good zip tie should keep em for flying all over the place. You could store em like that and then when you get ready to hunt just stab the poles into the receivers in the catwalks and go!
Author:  MNGunner [ Fri May 17, 2013 5:23 am ]
Put the gas tank in the hunt deck and a small rear platform to tuck the battery, bilge pump under. The one thing I don't like is getting in/out of the boat onto the hunt deck with the blind up for me and the dog. The battery box is right where I'd like to step.
Oh, yeah, and I would have bit the bullet and have them install the hydro-turf.
Other than that, nothing. 1754 Gator Trax Hybrid hunt deck (two gun boxes, one driver's, no extended front deck, front and rear grab rails, tall transom).
Author:  Gameover [ Fri May 17, 2013 6:06 am ]
Author:  Kmoppert [ Fri May 17, 2013 6:08 am ]
Author:  mcduffws [ Fri May 17, 2013 8:22 am ]
Author:  Will [ Fri May 17, 2013 8:39 am ]
Author:  kib876 [ Fri May 17, 2013 8:59 am ]
Author:  Robn1020 [ Fri May 17, 2013 9:00 am ]
I would have kept it! :cry:
Author:  dguidry [ Fri May 17, 2013 9:38 am ]
You mean something like this
Author:  Glades Ranger [ Fri May 17, 2013 12:13 pm ]
Like Jimmy said. Enjoyed all three previous boats, learning all the time. Hey, there were only LT's in the 80's and I am still using one and don't need an SD with a big block and umpteen accessories and mods. My second install was a beer holder so you get my priorities. I like stickers, got them on my boat and my truck, my boat is not camoed and I do fine. :mrgreen:
Author:  tailfisher17t [ Fri May 17, 2013 12:52 pm ]
I would have gone with a 2060 Duals and built how I wanted it to be built!
Also wouldn't have hooked up with some ladies in Thai land, japan, Vegas, South africa, Russia, Kosavo, Brazil,, camboita, and a few other places. Some present aren't worth having!!
Author:  KJH [ Fri May 17, 2013 2:58 pm ]
I'd would have 2" receiver in the front, a spud pole holder on each of the 4 corners, and a 1/8" bottom instead of a 3/16".
Author:  dfou [ Fri May 17, 2013 4:06 pm ]
Page 1 of 2 All times are UTC - 6 hours
