Gator Glide - Boat Dr. Product http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=44897 |
Page 1 of 2 |
Author: | schauv01 [ Sat Aug 31, 2013 6:38 am ] |
Post subject: | Gator Glide - Boat Dr. Product |
Has anyone tried the slick bottom coating product the Boat Dr. sells? He says its done in one coat and has it on his boat. Sent from my iPad using Tapatalk HD |
Author: | bbb [ Sat Aug 31, 2013 8:19 am ] |
Post subject: | Re: Gator Glide - Boat Dr. Product |
Well I would hope he uses it if he sells it. What does he call it? Gator Glide goes on in 3-4 coats. Steel Flex and other Epoxy type coatings go on in one coat. When it comes time to replace the epoxy type coats, I've been told you have to remove ALL existing material down to bare aluminum. I had Steel Flex on my boat and taking it down to bare aluminum took me a whole day with sanders, scrapers, and wire brush. I run around oyster bars about 3 months out if the year and have replace my coat ing every 18 months. If I only ran stump and hydrilla, I would opt for the epoxy type products as I believe they last longer. I bought a 6 yr old boat with the original coating and it was still slick as day one. |
Author: | schauv01 [ Sat Aug 31, 2013 8:26 am ] |
Can't remember what he called it, but said he could repair it without taking all it off. $150/gallon Sent from my iPad using Tapatalk HD |
Author: | schauv01 [ Sat Aug 31, 2013 12:53 pm ] |
Anybody? Sent from my iPad using Tapatalk HD |
Author: | OlSchool [ Sat Aug 31, 2013 12:58 pm ] |
You don't have to go down to bare aluminum to re-do epoxy. Remove any loose material, rough sand, wipe with acetone and re-coat. |
Author: | gmc [ Sat Aug 31, 2013 6:31 pm ] |
its called quick slick a buddy of mine did his boat last weekend and put two coats with a spray gun |
Author: | nasty [ Sat Aug 31, 2013 8:27 pm ] |
Pm frog. He'll get you hooked up. |
Author: | Frog [ Sun Sep 01, 2013 5:47 am ] |
Quick slick is a 2 part polyester /gel coat with slick added to it. It is not an epoxy. If u r going to apply I suggest you prep the bottom with a 36 grit wheel and a dust coating of zinc chromate not a film. |
Author: | CootSlayerRMFT [ Sun Sep 01, 2013 7:06 am ] |
While I respect Frog's modesty and helpfulness here, if I may interject, get Gator Glide and thank me later! You can do it yourself for about the same price WITHOUT flipping the boat. Touching it up or redoing it is easy. It works awesome! And most of all, Frog will be there to help you with any question you can come up with. I'll be calling him soon to hook me up with some more G2 to re-coat mine. Mine has lasted about 2 years, 250 engine hours, 2 duck seasons, and a lot of testing the limits of what "my first mud boat" could do... Read some of the Gator Glide threads on here, and think about this: If Frog is this willing to give you helpful tips when you're considering someone else's product, imagine how great he'll be to have around when you're buying his product! Best of luck to you with the new rig! |
Author: | schauv01 [ Sun Sep 01, 2013 8:00 am ] |
Author: | schauv01 [ Sun Sep 01, 2013 8:01 am ] |
Author: | mizzippi jb [ Sun Sep 01, 2013 8:04 am ] |
He's a dealer if I'm not mistaken. |
Author: | Bigrich [ Sun Sep 01, 2013 8:04 am ] |
He owns the company I do believe |
Author: | CJB [ Sun Sep 01, 2013 8:07 am ] |
Author: | Bigrich [ Sun Sep 01, 2013 8:09 am ] |
Author: | schauv01 [ Sun Sep 01, 2013 8:12 am ] |
Author: | Bigrich [ Sun Sep 01, 2013 8:15 am ] |
From what I have seen and read and from me Installing this on my rig u don't have to go bare metal just a good scuffing with a da and then wipe down with acetone then u ready to apply. I would think on the second application of this would be the same way. |
Author: | RootSumn [ Sun Sep 01, 2013 8:19 am ] |
Get it. I'll never have another duck boat without it. My boat's sitting completely on dry ground in the back yard right now and I'm about to go slide it back in the water by myself n shoot some crows. |
Author: | Bigrich [ Sun Sep 01, 2013 8:31 am ] |
X2 I promise u will love the GG! |
Author: | The Hairy Coot [ Sun Sep 01, 2013 8:33 am ] |
Author: | Bigrich [ Sun Sep 01, 2013 8:35 am ] |
Author: | bbb [ Sun Sep 01, 2013 9:11 am ] |
Double post |
Author: | bbb [ Sun Sep 01, 2013 9:14 am ] |
Author: | Frog [ Sun Sep 01, 2013 12:07 pm ] |
Author: | JIMMY W [ Sun Sep 01, 2013 3:57 pm ] |
Hey Frog,Say you use about 2 foot of boat to hold the front up and go ahead and GatorGlide the boat leaving that last 2 foot of rake undone,When you set boat back on trailer can you just do that section with base and g2? |
Author: | Bigrich [ Sun Sep 01, 2013 4:25 pm ] |
Jimmy what are u waiting on, time is ticking |
Author: | msm8281 [ Sun Sep 01, 2013 4:29 pm ] |
Author: | Bigrich [ Sun Sep 01, 2013 4:35 pm ] |
Author: | Bigrich [ Sun Sep 01, 2013 4:36 pm ] |
Author: | msm8281 [ Sun Sep 01, 2013 5:09 pm ] |
Author: | Bigrich [ Sun Sep 01, 2013 5:48 pm ] |
Author: | JIMMY W [ Sun Sep 01, 2013 6:14 pm ] |
Author: | Will [ Sun Sep 01, 2013 6:49 pm ] |
Author: | Bigrich [ Sun Sep 01, 2013 7:33 pm ] |
Author: | Will [ Sun Sep 01, 2013 8:30 pm ] |
Author: | Frog [ Mon Sep 02, 2013 8:06 am ] |
Author: | JIMMY W [ Mon Sep 02, 2013 11:14 am ] |
Gotcha,Tks |
Author: | Bigrich [ Mon Sep 02, 2013 11:17 am ] |
Author: | JIMMY W [ Mon Sep 02, 2013 2:00 pm ] |
Page 1 of 2 | All times are UTC - 6 hours |
