Pyramid seat base http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=46487 |
Page 1 of 2 |
Author: | dirtybird29+ [ Thu Oct 17, 2013 2:04 pm ] |
Post subject: | Pyramid seat base |
Who makes the pyramid seat bases? I've seen a few on here in the past . Sent from my iPhone using Tapatalk 2 |
Author: | sthomp [ Thu Oct 17, 2013 2:18 pm ] |
Post subject: | Re: Pyramid seat base |
Uncle J makes a pretty good one.. I've got 3 of his |
Author: | sthomp [ Thu Oct 17, 2013 2:19 pm ] |
Author: | dirtybird29+ [ Thu Oct 17, 2013 2:39 pm ] |
Thanks .. That's the ones I'm talking about. Sent from my iPhone using Tapatalk 2 |
Author: | Team Redneck [ Thu Oct 17, 2013 6:22 pm ] |
You can find 'em cheaper if you look around...... |
Author: | SCmudder7071 [ Thu Oct 17, 2013 6:28 pm ] |
Man put a cushion on that cooler and roll! ![]() |
Author: | dirtybird29+ [ Thu Oct 17, 2013 6:44 pm ] |
Been doing that for years now. Time for a change !!! ![]() |
Author: | TGunn [ Thu Oct 17, 2013 9:37 pm ] |
Jay at Instagator built these: |
Author: | instagator911 [ Thu Oct 17, 2013 10:13 pm ] |
Author: | TGunn [ Thu Oct 17, 2013 10:51 pm ] |
All good, man. Looking forward to getting her home so we can start the rigging. |
Author: | gundog05 [ Fri Oct 25, 2013 10:21 am ] |
Author: | dirtybird29+ [ Fri Oct 25, 2013 11:04 am ] |
Author: | krogers [ Fri Oct 25, 2013 11:09 am ] |
Author: | Pas Tout La [ Fri Oct 25, 2013 12:30 pm ] |
Do they attach to the boat in any way, or are they made to be moveable? I may be interested in a couple myself. |
Author: | krogers [ Fri Oct 25, 2013 12:32 pm ] |
Author: | krogers [ Fri Oct 25, 2013 12:33 pm ] |
Post subject: | |
Author: | whack [ Fri Oct 25, 2013 1:49 pm ] |
How tall are they with the seat on top? Sent from my XT1080 using Tapatalk 2 |
Author: | gundog05 [ Fri Oct 25, 2013 2:12 pm ] |
Author: | sthomp [ Fri Oct 25, 2013 3:03 pm ] |
I picked them up with the boat which he built. Can't remember how much they cost. They don't fasten to the boat in any way. I don't have a measurement on the seat height but for me I'm 6'3 and they're pretty perfect on height for me. |
Author: | sthomp [ Fri Oct 25, 2013 3:05 pm ] |
Author: | sthomp [ Fri Oct 25, 2013 3:08 pm ] |
Author: | krogers [ Fri Oct 25, 2013 6:39 pm ] |
Author: | sthomp [ Fri Oct 25, 2013 7:04 pm ] |
Author: | chaseh [ Fri Oct 25, 2013 8:15 pm ] |
Author: | CJB [ Fri Oct 25, 2013 8:25 pm ] |
J makes the seat bases about 10" tall, which works just fine, but I'd rather them be about 2-3" taller for me. I'm 6'4". He sells them for around $100, but the more you buy the cheaper they get. I believe he told me not long ago that two would be around $175. But it would be best to get in touch with him, which isn't always easy... |
Author: | sthomp [ Sat Oct 26, 2013 10:24 am ] |
Author: | gfowel [ Sat Oct 26, 2013 10:58 am ] |
I have J's seat bases. With Temptress hi back navi seats top of the seat cushion is at 17 1/2" the top of the back rest is at 35 3/4" |
Author: | DuckHunter [ Sat Oct 26, 2013 4:38 pm ] |
I'm having some of those made for my boat |
Author: | dixieducker [ Sat Oct 26, 2013 7:10 pm ] |
anyone ever built them out of stainless? The reason I ask is that I have a tig setup but it doesnt weld aluminum.. |
Author: | cb5331 [ Sat Oct 26, 2013 7:14 pm ] |
Seems like they would be heavy and expensive, but don't see why you couldn't if that's what you have to work with. |
Author: | dixieducker [ Sat Oct 26, 2013 7:18 pm ] |
I can get stainless at scrap price most of the time so I wouldnt have much money in them. And yes I know they would be heavier, just wonder how much more than aluminum. |
Author: | cb5331 [ Sat Oct 26, 2013 7:23 pm ] |
I'm sure there is a calculator online where you can type in the material type and thickness to get a guestimate on weight. They will be heavier, but wouldn't think it would be anything to be too concerned with. Just don't over build them. Use the thinnest material you can get away with. I have not seen anyone else build them out of anything but aluminum to more directly answer your question. Most of the guys making them build boats and have aluminum laying around, not stainless. |
Author: | dixieducker [ Tue Nov 05, 2013 3:48 pm ] |
Can someone give me some dimensions? |
Author: | cb5331 [ Tue Nov 05, 2013 3:58 pm ] |
Use the search. I've posted pics and dimensions more than once. |
Author: | willett [ Tue Nov 05, 2013 7:26 pm ] |
The ones I make vary with the customer but we've made some as small as 16 x 16 base and are 13" tall then with the seat they are pretty much perfect. Have made them wider and shorter but the 16 x 16 has good balance and doesn't take up a ton of room like the wider bases. I sale the 16 x 16 x 13 tall for $100 with single color paint. Can get any kind of seats also for cheaper than most retail options but the more you buy the better the deal |
Author: | North LA Hunter [ Tue Nov 05, 2013 7:51 pm ] |
.100 alum 5086 is 1.38 lbs per sq ft. .125 alum 5086 is 1.728 lbs per sq ft. 16 ga (.0508) 304 stainless is 2.0994 lbs per sq ft. Not much of a difference but it is heavier. I would go with alum. Sent from my beeper. |
Author: | dixieducker [ Tue Nov 05, 2013 8:01 pm ] |
Thanks guys. |
Author: | North LA Hunter [ Tue Nov 05, 2013 8:04 pm ] |
Author: | dixieducker [ Tue Nov 05, 2013 8:13 pm ] |
I have argon, just dont have a high frequency box. |
Page 1 of 2 | All times are UTC - 6 hours |
