It is currently Wed Mar 18, 2026 1:06 pm
[ 3 posts ] |
Older Gator Tail and question on rig
luv2cmwork
I hunt hard dirt bottom. Anywhere from 4 foot or more, to as little as 6 inches. No problem with an outboard in the deeper depths, but LOTS of weeds/grasses in the middle depths, to shallows make an outboard frustrating. No mud, to speak of...at least not the "boggy" type mud I see on videos.
I'm looking at purchasing a complete rig. A 1648 rig, with a older (could be first generation maybe?) 23 hp Gatortail. It appears to be a flat bottom (no mod v front) jon boat.
Keeping in mind my environment of vegetation mostly, is the rig suitable? Also, any issues with the first Gator tails? This seems to be an older model.
Thanks!
| Thu Oct 24, 2013 1:03 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: Older Gator Tail and question on rig
A longtail is generally better on hard ground. But if you don't stop in a sd and keep your momentum going you will be fine on hard bottom. But lt doesn't do AS good as a sd in the grass. I run some hard bottom areas and does decent but you can't stop and try to get back up on step.
Sent from my beeper.
| Thu Oct 24, 2013 1:10 pm |
Goose Crumpler
Joined: Thu Dec 02, 2010 9:51 am Posts: 1404 Location: Northern Wisconsin
I run mostly sand and boulders, very little mud and lots of grass. SD= don't stop in shallow water, if you do be prepared to walk boat to deeper water.
| Thu Oct 24, 2013 1:37 pm |
[ 3 posts ] |
