fastest hull??? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=47281 |
Page 1 of 2 |
Author: | jtwilliams [ Mon Nov 11, 2013 4:03 pm ] |
Post subject: | fastest hull??? |
I know this is going to start an opinion war. But on average what is the fastest hull? also with chines, or without chines? |
Author: | btmannin [ Mon Nov 11, 2013 4:08 pm ] |
Post subject: | Re: fastest hull??? |
simply put.. square tends to be a little faster, slides in turns, Round chine drafts more, a little slower and doesnt slide when turning at high speed.... and then there's tapered chines: Single, double, triple, single being most similar to a round,, and triple being similar to square. |
Author: | dadazzsaleen [ Mon Nov 11, 2013 4:16 pm ] |
^^ triple taper is closer to round. There's 3 bends in the chine. A single taper is more like a 45 degree vs a 90 degree of a square. |
Author: | eljefe [ Mon Nov 11, 2013 4:22 pm ] |
Instagator. .... sent from the former Republic of Texas. |
Author: | nasty [ Mon Nov 11, 2013 4:23 pm ] |
17x48 square chine. If we're talking stock motors. |
Author: | btmannin [ Mon Nov 11, 2013 4:43 pm ] |
Author: | cupped up [ Mon Nov 11, 2013 5:49 pm ] |
STV's are pretty fast. They're tunnel hulls though. Allison XR2001's roll too, they are V bottom pad hulls, kinda a stepped chine design. |
Author: | jtwilliams [ Tue Nov 12, 2013 12:39 pm ] |
im talking stock motor 35hp |
Author: | banded-mallard [ Tue Nov 12, 2013 1:06 pm ] |
17-18' 48"-54" bottom, lite as possible. Depending on what and where you hunt, go 1/8" bottom, .100 sides, hat section for ribs. Want to say luceur had a hull made that was all .100 for a GTR25. Thats about as lite as you can go. But if you run any kind od swamp or trees or stumps, you should go 3/16 bottom. Weight has as much to do with the hull design. |
Author: | 270Handiman [ Tue Nov 12, 2013 2:51 pm ] |
This is easy..........whatever boat AKAwhatever is in. Just ask him, he'll tell you. ![]() Whatever you get, you're gonna have chines of some sort, you just have to decide how you want them shaped. |
Author: | Jamie B. [ Tue Nov 12, 2013 3:13 pm ] |
[quote="270Handiman"]This is easy..........whatever boat AKAwhatever is in. Just ask him, he'll tell you. ![]() ![]() ![]() |
Author: | dfou [ Tue Nov 12, 2013 4:08 pm ] |
Author: | AKA Freshwaterkilla [ Tue Nov 12, 2013 7:58 pm ] |
Author: | banded-mallard [ Wed Nov 13, 2013 5:31 am ] |
Author: | Swamp Wader [ Wed Nov 13, 2013 5:49 am ] |
17 48 square |
Author: | Will [ Wed Nov 13, 2013 6:26 am ] |
The rake effects top speed also, changes how much surface area you have on the water. You want just enough flat bottom it to get on top like a skim board and not cutting through the water creating drag. The width is a variable in this as well. |
Author: | Woodiebuster [ Wed Nov 13, 2013 12:19 pm ] |
But, a longer more gradual rake will plane out and run much better |
Author: | Will [ Wed Nov 13, 2013 12:25 pm ] |
You should say and, not but... you're adding to what I was saying and have a point. |
Author: | banded-mallard [ Wed Nov 13, 2013 12:50 pm ] |
Author: | dfou [ Wed Nov 13, 2013 1:20 pm ] |
I think he means like this And the correct answer to the question is, whatever hull my motor is on Sent from my iPhone using |
Author: | Will [ Wed Nov 13, 2013 1:30 pm ] |
Author: | banded-mallard [ Wed Nov 13, 2013 1:33 pm ] |
Author: | dfou [ Wed Nov 13, 2013 1:34 pm ] |
Author: | dfou [ Wed Nov 13, 2013 1:36 pm ] |
Although this one is a big boat with a short rake and ran the same speeds as y'all's Sent from my iPhone using |
Author: | eljefe [ Wed Nov 13, 2013 5:46 pm ] |
Instagator..... they got mojo in them..... sent from the former Republic of Texas. |
Author: | Boomer [ Thu Nov 14, 2013 9:44 am ] |
Author: | banded-mallard [ Thu Nov 14, 2013 10:01 am ] |
Author: | jtwilliams [ Thu Nov 14, 2013 10:17 am ] |
you building them yourselve? and that rake being so long how does it do in rougher water? |
Author: | banded-mallard [ Thu Nov 14, 2013 10:32 am ] |
Author: | Jamie B. [ Thu Nov 14, 2013 10:33 am ] |
Like dis ![]() IMG_4943.jpg |
Author: | banded-mallard [ Thu Nov 14, 2013 10:35 am ] |
Author: | dfou [ Thu Nov 14, 2013 11:30 am ] |
Author: | banded-mallard [ Thu Nov 14, 2013 12:01 pm ] |
Author: | Will [ Thu Nov 14, 2013 12:09 pm ] |
Second mark 37-39, that's that throw a fucker off a cooler shit right there ![]() |
Author: | Bigrich [ Thu Nov 14, 2013 12:16 pm ] |
That hull was like a 100 gauge too. |
Author: | dfou [ Thu Nov 14, 2013 12:18 pm ] |
Author: | banded-mallard [ Thu Nov 14, 2013 12:20 pm ] |
Author: | instagator911 [ Thu Nov 14, 2013 12:24 pm ] |
Author: | Bigrich [ Thu Nov 14, 2013 12:28 pm ] |
Author: | instagator911 [ Thu Nov 14, 2013 12:32 pm ] |
Its no prob. there are a list of things that will make a hull faster and set right. most importantly is drying the hull for less drag. Not all hulls are the same i.e. 1646 vs 1646. |
Page 1 of 2 | All times are UTC - 6 hours |
