It is currently Fri Dec 19, 2025 2:58 pm
Reply to topic  [ 63 posts ]  Go to page 1, 2  Next
 fastest hull???
Post fastest hull???
I know this is going to start an opinion war. But on average what is the fastest hull? also with chines, or without chines?
Mon Nov 11, 2013 4:03 pm
Post Re: fastest hull???
simply put.. square tends to be a little faster, slides in turns, Round chine drafts more, a little slower and doesnt slide when turning at high speed.... and then there's tapered chines: Single, double, triple, single being most similar to a round,, and triple being similar to square.
Mon Nov 11, 2013 4:08 pm
^^ triple taper is closer to round. There's 3 bends in the chine.
A single taper is more like a 45 degree vs a 90 degree of a square.
[Stage 2.5]
Mon Nov 11, 2013 4:16 pm
Instagator. ....
sent from the former Republic of Texas.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Mon Nov 11, 2013 4:22 pm
17x48 square chine. If we're talking stock motors.
Mon Nov 11, 2013 4:23 pm
Mon Nov 11, 2013 4:43 pm
STV's are pretty fast. They're tunnel hulls though. Allison XR2001's roll too, they are V bottom pad hulls, kinda a stepped chine design.
Mon Nov 11, 2013 5:49 pm
im talking stock motor 35hp
Tue Nov 12, 2013 12:39 pm
17-18' 48"-54" bottom, lite as possible. Depending on what and where you hunt, go 1/8" bottom, .100 sides, hat section for ribs. Want to say luceur had a hull made that was all .100 for a GTR25. Thats about as lite as you can go. But if you run any kind od swamp or trees or stumps, you should go 3/16 bottom. Weight has as much to do with the hull design.
Tue Nov 12, 2013 1:06 pm
This is easy..........whatever boat AKAwhatever is in. Just ask him, he'll tell you. :lol:
Whatever you get, you're gonna have chines of some sort, you just have to decide how you want them shaped.
Tue Nov 12, 2013 2:51 pm
[quote="270Handiman"]This is easy..........whatever boat AKAwhatever is in. Just ask him, he'll tell you. :lol:
:lol: :lol:
Tue Nov 12, 2013 3:13 pm
Tue Nov 12, 2013 4:08 pm
Tue Nov 12, 2013 7:58 pm
Wed Nov 13, 2013 5:31 am
17 48 square
Wed Nov 13, 2013 5:49 am
The rake effects top speed also, changes how much surface area you have on the water. You want just enough flat bottom it to get on top like a skim board and not cutting through the water creating drag. The width is a variable in this as well.
Wed Nov 13, 2013 6:26 am
But, a longer more gradual rake will plane out and run much better
Wed Nov 13, 2013 12:19 pm
You should say and, not but... you're adding to what I was saying and have a point.
Wed Nov 13, 2013 12:25 pm
Wed Nov 13, 2013 12:50 pm
I think he means like this
And the correct answer to the question is, whatever hull my motor is on
Sent from my iPhone using
Wed Nov 13, 2013 1:20 pm
Wed Nov 13, 2013 1:30 pm
Wed Nov 13, 2013 1:33 pm
Wed Nov 13, 2013 1:34 pm
Although this one is a big boat with a short rake and ran the same speeds as y'all's
Wed Nov 13, 2013 1:36 pm
Instagator..... they got mojo in them.....
Wed Nov 13, 2013 5:46 pm
1748 Boomer Custom in progress
Thu Nov 14, 2013 9:44 am
Thu Nov 14, 2013 10:01 am
you building them yourselve? and that rake being so long how does it do in rougher water?
Thu Nov 14, 2013 10:17 am
Thu Nov 14, 2013 10:32 am
Like dis 8-)
Thu Nov 14, 2013 10:33 am
Thu Nov 14, 2013 10:35 am
Thu Nov 14, 2013 11:30 am
Thu Nov 14, 2013 12:01 pm
Second mark 37-39, that's that throw a fucker off a cooler shit right there :lol:
Thu Nov 14, 2013 12:09 pm
That hull was like a 100 gauge too.
Thu Nov 14, 2013 12:16 pm
Thu Nov 14, 2013 12:18 pm
Thu Nov 14, 2013 12:20 pm
Jay Dore
Thu Nov 14, 2013 12:24 pm
Thu Nov 14, 2013 12:28 pm
Its no prob. there are a list of things that will make a hull faster and set right. most importantly is drying the hull for less drag. Not all hulls are the same i.e. 1646 vs 1646.
Jay Dore
Thu Nov 14, 2013 12:32 pm
