New light bracket http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=48394 |
Author: | david95 [ Tue Dec 17, 2013 5:43 pm ] |
Post subject: | New light bracket |
Got tired of holding a Qbeam so ima try this, just gotta get some paint an get the wires taped up. Made it so I can just pull the bolt an take em out the way. Sent from my DROID RAZR using Tapatalk 2 |
Author: | krogers [ Tue Dec 17, 2013 5:47 pm ] |
Post subject: | Re: New light bracket |
Man I think it's gonna work. Only problem I see is the self tappers the flat bar is mounted to your bow with. Watch they may try to back out, esp w a mm. Good work tho. If it helps then it works |
Author: | SmokeEater829 [ Tue Dec 17, 2013 8:46 pm ] |
Should work good. Might want to look into getting some nutserts instead of the self tapping screws. I have used them all over my boat with no problems. |
Author: | msm8281 [ Tue Dec 17, 2013 9:28 pm ] |
It will draw alot of juice if thats two qbeams. |
Author: | North LA Hunter [ Tue Dec 17, 2013 9:36 pm ] |
Screw do not do well in boats. Bolts with lock nuts or this riv nuts are the best way to go. Sent from my beeper |
Author: | mudslut [ Tue Dec 17, 2013 10:53 pm ] |
X3 on the riv nuts. U can pick a tool and a few inserts up off of eBay for around $40 Sent from my iPhone using Smoke Signals |
Author: | david95 [ Wed Dec 18, 2013 6:40 am ] |
Thanks for the input, I cant put a bolt cause I cant get a nut under that lip but Ima get some riv nuts for it that's a good idea I didn't think about. Sent from my DROID RAZR using Tapatalk 2 |
Author: | DmaxHunter [ Wed Dec 18, 2013 12:02 pm ] |
Harbor freight, had riv nut set for under thirty. But yes riv nuts are pretty sweet Sent from my DROID RAZR using Tapatalk |
