| Floor drains? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=48842 |
| Author: | North LA Hunter [ Sat Jan 04, 2014 10:00 am ] |
| Post subject: | Floor drains? |
In a full welded floor are you boat builders putting drains in the floor up against the cross brace? I've seen gt boats and they don't have any in them. I'm thinkin about putting one on each side on the down hill side of the floor. Any need in them? Or just let them overflow when they get full? Sent from my beeper |
| Author: | MNGunner [ Sat Jan 04, 2014 10:07 am ] |
| Post subject: | Re: Floor drains? |
That'd be a lot of water sitting in there potentially, wouldn't it. Up here that'd freeze and have some nice little skating rinks. I guess that's one of the benefits of gutters. |
| Author: | North LA Hunter [ Sat Jan 04, 2014 10:09 am ] |
| Author: | OlSchool [ Sat Jan 04, 2014 10:12 am ] |
I have often wondered why you wouldn't use 1x2 on side braces and drop it down in the longitudal braces so the floor is flush. More work I know but would be nice to have a flat floor. |
| Author: | MNGunner [ Sat Jan 04, 2014 10:15 am ] |
| Author: | dfou [ Sat Jan 04, 2014 10:16 am ] |
Sent from my iPhone using |
| Author: | dfou [ Sat Jan 04, 2014 10:17 am ] |
| Author: | North LA Hunter [ Sat Jan 04, 2014 10:17 am ] |
| Author: | MNGunner [ Sat Jan 04, 2014 10:18 am ] |
| Author: | North LA Hunter [ Sat Jan 04, 2014 10:19 am ] |
| Author: | North LA Hunter [ Sat Jan 04, 2014 10:21 am ] |
| Author: | OlSchool [ Sat Jan 04, 2014 10:29 am ] |
| Author: | North LA Hunter [ Sat Jan 04, 2014 10:45 am ] |
| Author: | OlSchool [ Sat Jan 04, 2014 10:50 am ] |
| Author: | dfou [ Sat Jan 04, 2014 4:53 pm ] |
Their are better options for recessed cross braces Sent from my iPhone using |
| Author: | North LA Hunter [ Sat Jan 04, 2014 4:59 pm ] |
| Author: | cr244 [ Sun Jan 05, 2014 10:48 am ] |
| Author: | North LA Hunter [ Sun Jan 05, 2014 12:54 pm ] |
| Author: | OwenDickeson [ Sun Jan 05, 2014 1:16 pm ] |
| Author: | Nate [ Sun Jan 05, 2014 2:19 pm ] |
If you ever run salt marsh I wouldn't do any sort of drains...that salt buildup is hell on alum over time |
| Author: | cr244 [ Sun Jan 05, 2014 5:12 pm ] |
LOL! i hear you brandon. is that boat the 1 for that fella in Fl. we talked about. |
| Author: | cr244 [ Sun Jan 05, 2014 5:17 pm ] |
| Author: | dfou [ Sun Jan 05, 2014 5:23 pm ] |
I've bent 2x2x.125 cross bracing Sent from my iPhone using Tapatalk |
| Author: | OlSchool [ Sun Jan 05, 2014 5:52 pm ] |
Sounds like Dfou and Owen could destroy a tank.... |
| Author: | MNGunner [ Sun Jan 05, 2014 6:08 pm ] |
| Author: | Nate [ Sun Jan 05, 2014 6:22 pm ] |
Just my opinion but No, those drains just let the salt water access a lot of hard to get to areas, nooks and crannys under the false floor...sure you can flush it out but your not going to get it all. With a fully welded sealed false floor it eliminates the possibility. We run all aluminum boats with work and over time have problems with areas similar to this.. |
| Author: | dfou [ Sun Jan 05, 2014 6:27 pm ] |
I would venture to guess not many have a truest sealed double bottom Sent from my iPhone using Tapatalk |
| Author: | North LA Hunter [ Sun Jan 05, 2014 7:39 pm ] |
| Author: | dfou [ Sun Jan 05, 2014 7:44 pm ] |
Water can't get under the front or the back? It's sealed around the runners and to the bottom? Sent from my iPhone using Tapatalk |
| Author: | nasty [ Sun Jan 05, 2014 8:44 pm ] |
Seems like your longitudinals would have to be capped then completely welded along the farthest cross brace in the back to the bottom, the front bulkhead err thang gotta be welded and sealed |
| Author: | North LA Hunter [ Sun Jan 05, 2014 8:55 pm ] |
| Author: | dfou [ Sun Jan 05, 2014 8:59 pm ] |
What about inside the front hatch? It's sealed to the floor? I don't know of many that are Sent from my iPhone using Tapatalk |
| Author: | North LA Hunter [ Sun Jan 05, 2014 9:28 pm ] |
| Author: | OwenDickeson [ Sun Jan 05, 2014 9:33 pm ] |
Brother does some fully sealed double bottoms, but its different than most ive seen on here. |
| Author: | dfou [ Sun Jan 05, 2014 9:35 pm ] |
| Author: | dfou [ Sun Jan 05, 2014 9:36 pm ] |
| Author: | Dmstrucks/02 [ Mon Jan 06, 2014 4:14 am ] |
I did this, helps a ton when washing Sent from my SAMSUNG-SGH-I537 using Tapatalk |
| Author: | North LA Hunter [ Mon Jan 06, 2014 5:40 am ] |
| Author: | banded-mallard [ Mon Jan 06, 2014 6:02 am ] |
