It is currently Fri Aug 21, 2026 8:49 pm
Reply to topic  [ 30 posts ]
 removing foam from my boat ?
Post removing foam from my boat ?
just bought a used mud rig. a 18/56 Go-Devil mud boat with a 35 console drive GTR . it weighs a ton. I thought about removing the foam from in side the front hunt deck and floor. good idea ? just want yalls opinion on that. im also moving the gas tank from the back to the front of the boat. repainting the boat. trying to rid of some of the unneeded wieght
Mon Jan 13, 2014 7:42 am
Post Re: removing foam from my boat ?
Congrats on the new rig. Every time this question comes up the majority says to take that shit out. Only Giga will tell you to replace it.
Mon Jan 13, 2014 9:21 am
If the foam is waterlogged I can see pulling it out, or if you were doing some mods. But would you not want to replace it so if somehow you swamp the thing it doesn't sink? I removed all foam for mods but am adding it back wherever I can and am shooting for the same volume of foam just so if by some freakish accident I take on that much water it lingers at the surface instead of sinking to the bottom. If waterlogged it will be heavy otherwise you arent cutting much weight with foam removal.
Backwater Swomp 23 / Lowe L1448M
Mon Jan 13, 2014 9:36 am
Buddy took the floor out and used a pressure washer to blast it out. removed the foam but didn't damage anything else.
Mon Jan 13, 2014 10:00 am
I had a boat with foam and it was heavy so i assumed the foam was waterlogged I cut my front deck and floor out and the foam was dry as could be. Im just saying you need to make sure the boat is heavier than it should be with a scale before you cut your boat up for nothing like i did.
Mon Jan 13, 2014 10:16 am
I took a saw zall first and cut a whole bunch of slits all in it and started pressure washing but it makes a mess make sure u put a face shield on that lil foam goes everywhere and it feels like sandpaper in ur eyes
Sent from my iPhone using
Mon Jan 13, 2014 10:22 am
I just drilled the rivets out took the flooring off and cut the foam where the split seats are . Let it sit out in the sun for a day and it dried up then I put it back in . Just the bottom of the foam was wet , not the entire piece.
Talks cheap, it takes money to buy whiskey hoss
Mon Jan 13, 2014 10:31 am
Thanks for the advice. The boat is diffinatley to heavy. It's an 04 boat so my guess most of the foam is no longer any good. What other ways can I reduce weight? I'm moving the gas tank from the back of the boat to the front . To reduce weight in the back of the boat.
Mon Jan 13, 2014 11:36 am
Remove that damn deck and split seat. I'll put you in a nice center seat.
Mon Jan 13, 2014 11:51 am
Mon Jan 13, 2014 11:54 am
I like the deck and split seat. I doo wanna take weight off but there's some things that are not negotiable . I like that set up. I might just have to settle with the way it is . Yes that would make it lighter minus any sitting room
Mon Jan 13, 2014 1:11 pm
Take tha back I'm not against taking out the back deck
Mon Jan 13, 2014 1:23 pm
Why not take out the back deck both seats and put a seat infront of the console, and a seat behind it. That would put more weight upfront and reduce the weight in the back significantly
Mon Jan 13, 2014 3:18 pm
Foam in a boat is the second most stupid thing that coco has done!
Mon Jan 13, 2014 6:39 pm
1648 gd hull flying in front of a stage 3 with fpr
Mon Jan 13, 2014 8:06 pm
Good old circular saw and a pressure washer. Need the "rotating concrete" tip. Make sure you wear a face mask with goggles under it, long sleeve t-shirt and gloves. Its not a fun job but can do it in a couple of hours. Took a garbage can of foam out and took two people to drag it to the street after the water ran out of the can. The foam was definitely water logged and made some pitting in the aluminum.
Mon Jan 13, 2014 8:10 pm
Mon Jan 13, 2014 8:13 pm
Gator tail
Mon Jan 13, 2014 8:25 pm
What's sucks is I'll have to make a whole on the inside of my front hunt deck. But I'm pretty sure it will be water logged, especially in the floor. Thanks for the tips guys !
Mon Jan 13, 2014 8:37 pm
I would like to remove that back deck and slide those bench seats back. That would give me room for a seat behind and infrony of the console.
Mon Jan 13, 2014 8:43 pm
viewtopic.php?f=4&t=36399&p=433498&hilit=gd+foam+removal#p433498
Mon Jan 13, 2014 8:46 pm
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Jan 13, 2014 8:48 pm
I might remove the deck behind the seats and slide the seats back in there place. I like how the set up is. I don't want a boat hull and no seating. Nice having room for others to sit not obstructing my view sitting on the front deck.i have no use for the back deck. I do like the storage under the side seats. Other then that I have no storage.
Mon Jan 13, 2014 9:11 pm
17/54 gator tail extreme with a stage 2 gator tail strapped on the back
viewtopic.php?f=5&t=43412
Mon Jan 13, 2014 10:24 pm
Tue Jan 14, 2014 6:25 am
Tue Jan 14, 2014 7:09 am
Tue Jan 14, 2014 8:55 am
What do y'all recommend for seats ? I wanna rid of the old ones
Tue Jan 14, 2014 8:16 pm
Tue Jan 14, 2014 9:28 pm
I want to slide back the benches and and console ( which is more to the front of the boat then center ). I'm removing the foam in the front . Not ripping the front deck off. If I wanted a boat with just a hull I could sale the boat and buy just a hull. Where I'm cutting the deck on the boat , I am putting the gas tank there. I'm rearranging the boat for room for me and others to sit in a pop up blind ( main reason I'm moving the benches and console back ). I understand what ur saying nasty , but I like the benches in the back.
Wed Jan 15, 2014 8:22 pm
